Hi all,
New member who has been given a CubeX 3d printer that has only been used once and found in storage.
I have downloaded KISSlicer v1.6.3 Release Win64 and CubeItMod605.
When I go to save my file on the flash drive I get the following error:
Running the post process command:
CubeItMod605.exe "E:\ STL.bfb"
Failed, returning 1
Looking at clips on youtube I suspect I have the incorrect G-code? do you think this is the issue?
Any help much appreciated.
printer G-Code
- ksh_germany
Re: printer G-Code
The post process command should be this:
CubeItMod605.exe {InputFileName}
Or this
CubeItMod.exe "<FILE>"
Or this
Re: printer G-Code
I have tried renaming the post-process. Am I missing something simple. Sorry to be pain but new time user
- Capture.PNG (43.77 KiB) Viewed 10634 times
- Capture 3.PNG (34.46 KiB) Viewed 10634 times
- Capture 1.PNG (6.19 KiB) Viewed 10634 times
Re: printer G-Code
Thanks for . Can you look at the photos above and see if there is any obvious errors? Thank againksh_germany wrote: ↑02 Apr 2020, 03:38 The post process command should be this:
Or this
- ksh_germany
Re: printer G-Code
i see the Problem there is no cubeitmod.exe in your Kisslicer Folder, sorry but so it can't run
you have to download "download/file.php?id=683" unzip in your Kisslicer Folder and set post-process
Cubitmod605.exe "<FILE>"
