Bed placement with multiple objects
Msquare
Post by Msquare »
This feature was requested as part of another thread, so I am just putting it in its own thread here. Besides, I miss it, want it, need it.
I notice that with a single part, I can move it around the bed. (Personal sideissue:There is the minor problem that movement is limited by the "square outline" of the part, as opposed to its actual outline. That means that on my round bed (of my delta Spiderbot) the placement ofa round part is much limited (ie the part lies inside the square which is inside the round bed.))
For multiple parts, the "move" buttons only moves everything together. (For me the square/roundbed effectivly limts the movement - and I have tried changing the "Bed is round" tick mark - marginal difference) I can not arrange anything. Only autoplace. As mentioned by others, this also includes the support stuctures (pillar, particularily multiple extruder).
A fun bit is if I place two round parts on the bed. If I rotate one part - that bit works fine for indivdual parts by the way - then both parts find new positions :shock: . Rotate back, they also go to the original position. So the part placement algorithm is sensitive to the rotation, even though it does not change. I have used this, rotating my 3 round gears on the bed until I stumble on a combination where the placement is acceptable.
So - the feature request: The feature is only enabled in Expert mode. When a part is highlighted, then it can be moved with the movesliders. The autoplacement is disabled after the first move, until one presses the centre button. Illegal moves are permitted, enabling the placement of parts "on top of each other". This is a neccessary transient state when rearranging. It might also be reasonable where one can place a small part inside a ring as an example. The slicer might issue a warning before starting or when it detects crossing lines, or suchlike, of overlapping parts. Overlapping of the square outline is highly likely without being bad - f.eks. nestling of semi circles.
Whilst it would be real nice to be able to move the parts around with the mouse, I think it is sufficient if the movement is done with those slider buttons, and part selection is done in the right column. That should limit the programming effort.
0110-m-p
Re: Bed placement with multiple objects
Post by 0110-m-p »
+1 for this feature.
Thanks for creating this separate feature request.
-another delta user
Printer: Rostock Max w/ E3D V5 hotend and lots of upgrades/modifications
getSurreal
Post by getSurreal »
+1 I would really like this feature.
MLWorx
Post by MLWorx »
Definitely would need this arrange feature too:
Since my printbed on one printer is just 140*140mm and I do print 3mm outline on each part (sticks very well then...) I ALWAYS have to arrange the stls with RepetierHost, pack it into a single stl and import it into Kisslicer :?
n3rdglass
Post by n3rdglass »
any update on this feature request? it is difficult to arrange multiple models on the print bed without it.
sinned6915
Post by sinned6915 »
+1 to everything above
it would also be nice to have some coordinate system to input or adjust and fine tune things. as much as I hate to say it, the model manipulation controls in S3D are pretty intuitive and useful. having some functionality like entering offsets or locations, rotations, etc. directly would be nice. right clicking the model list on the right is not intuitive.
Tinchus2009
Post by Tinchus2009 »
I was going to post the same feature request, I guess is better to just say +1 here :)
Yes, definitly a needed feature is to move each model indicidually in the bed.
This is on the "internal" feature request list, although that list is very long with some much more important issues which will need to be completed first.
