I notice that with a single part, I can move it around the bed. (Personal sideissue:There is the minor problem that movement is limited by the "square outline" of the part, as opposed to its actual outline. That means that on my round bed (of my delta Spiderbot) the placement ofa round part is much limited (ie the part lies inside the square which is inside the round bed.))
For multiple parts, the "move" buttons only moves everything together. (For me the square/roundbed effectivly limts the movement - and I have tried changing the "Bed is round" tick mark - marginal difference) I can not arrange anything. Only autoplace. As mentioned by others, this also includes the support stuctures (pillar, particularily multiple extruder).
A fun bit is if I place two round parts on the bed. If I rotate one part - that bit works fine for indivdual parts by the way - then both parts find new positions
So - the feature request: The feature is only enabled in Expert mode. When a part is highlighted, then it can be moved with the movesliders. The autoplacement is disabled after the first move, until one presses the centre button. Illegal moves are permitted, enabling the placement of parts "on top of each other". This is a neccessary transient state when rearranging. It might also be reasonable where one can place a small part inside a ring as an example. The slicer might issue a warning before starting or when it detects crossing lines, or suchlike, of overlapping parts. Overlapping of the square outline is highly likely without being bad - f.eks. nestling of semi circles.
Whilst it would be real nice to be able to move the parts around with the mouse, I think it is sufficient if the movement is done with those slider buttons, and part selection is done in the right column. That should limit the programming effort.
