Ability to run script from within KISS
sinned6915
Post by sinned6915 »
Jonathan et al-
I would like to request the ability to run a script from within KISS, specifically to upload to Octoprint.
This is how they do it from within S3D-
https://github.com/foosel/OctoPrint/wik ... -Octoprint
using CURL- https://curl.haxx.se/using command lines to send data.
best regards,
dennis
Re: Ability to run script from within KISS
Is it possible to use the Settings/Printer/Firmware/Post-Process entry field for this?
pjr wrote:Is it possible to use the Settings/Printer/Firmware/Post-Process entry field for this?
It is. That's how I upload and print from kisslicer on the duet.
sinned6915
Thank you for showing me where this is.
How are you connecting and sending to the duet? What is the connection or protocol that you are using?
sinned6915
[quote="pjr"]Is it possible to use the Settings/Printer/Firmware/Post-Process entry field for this?
It IS possible! We should move this from Feature requests to Tips & Tricks! Here is my script using curl. I got some assistance in final debug from Jubaleth on freenode reprap irc.
ECHO ON
ECHO FILENAME %1
curl -k -H "X-Api-Key: *YOUR_OCTOPRINT_API_HERE*" -F "select=false" -F "print=false" -F "file=@""%1""" "http://192.168.*.*/api/files/local"
PAUSE
sinned6915 wrote:Thank you for showing me where this is.
The duet's protocol is described somewhere on the duet site or in the reprapfirmware's code, can't tell now, been a while, but it's basically
curl --data-binary @"$inf" "${endpoint}rr_upload?name=$upf&time=$ft
where ft is file time:
ft="$(TZ=UTC date -r "$inf" +%Y-%m-%dT%H:%M:%S)"
and potentially initiate printing:
curl -s "${endpoint}rr_gcode?gcode=M32%20%22/${upf}%22"
Those are fragments of one shell script that is invoked with different parameters by applescript that presents dialog (like upload/print/nothing). Things are happening on mac, as you might have guessed. The recipe also applies to linux, not sure how exactly to deal with that on windows, but should be possible.
sinned6915
The syntax that works in KISS_2.0 seems to be -
YOUR_SCRIPT.BAT "<FILE>"
YOUR_SCRIPT.BAT contains-
curl -k -H "X-Api-Key: **API_KEY**" -F "select=false" -F "print=false" -F file=@%1 "http://octoprint.local/api/files/local"
