Preload wizard - what am I looking for?
abecker
Re: Preload wizard - what am I looking for?
Post by abecker »
I just finished my preload test from 0 - 1. Do I have any layers that are 'good'? It posted the picture sideways but the 0 side is on the right and 1 side is on the left.
Could you please zip and post the G-code?
abecker
Post by abecker »
PreloadTune1.gcode.zip
(70.97 KiB) Downloaded 205 times
BoriSpider
Post by BoriSpider »
Seam on the side, what a novel idea. Probably easier to read than on the corner like mine.
abecker
Post by abecker »
I used the profile from the kisslicer weebly page for the D300VS and that is how it printed
I just looked over your G-code. Your Drive Length is 78 mm, which is a nice tight direct drive. You won't really need the Preload functionality on your extruder for stiff materials like PLA (so I would just leave the PreloadVE value at the wizard default for PLA which is 0.75). The Preload function will be much more useful if you want print in TPU or, to a lesser extent, in materials like Nylon.
(I have a Bowden system where the my Drive Length is almost 10x yours at 730 mm, and I absolutely need Preload to print with clear NinjaFlex...because my custom printed Ping Pong paddles needed those clear rubber pads [8^)
thanks, and sorry for any confusion,
Ronin
Post by Ronin »
lonesock wrote:I just looked over your G-code. Your Drive Length is 78 mm, which is a nice tight direct drive. You won't really need the Preload functionality on your extruder for stiff materials like PLA (so I would just leave the PreloadVE value at the wizard default for PLA which is 0.75). The Preload function will be much more useful if you want print in TPU or, to a lesser extent, in materials like Nylon.
I have rebuilt my printer and change bowden to direct drive extruder (titan). It's about 100mm from drive to nozzle. Do I need Preload functionality or it's better to turn it off? I print ABS, PLA, SBS, PET-G, HIPS
altarke
Post by altarke »
I am a KISS User for some time - and loving it. I must admit that the promise of the new battery of wizards is very promising and welcome, my problem is that, at this point in time, they are a bit ambiguous and unclear.
For starters,
• what is the right sequence of running the wizards
• what particular STL's are needed (I did notice some suggestions in the wizard, but it is not clear)
• What, in particular, are we looking for in every step of the wizards.
It would be great if there was, even a brief, document describing the workflow of the wizards. This way the full benefit of the great KISSlicer can be fully realized.
Thanks to everyone who participates in the development of this great slicer.
altarke
Heavily modded Rostock MAX V1, E3D V5 Hotend, Ultimaker Original with E3D V6
altarke wrote:I am a KISS User for some time - and loving it. I must admit that the promise of the new battery of wizards is very promising and welcome, my problem is that, at this point in time, they are a bit ambiguous and unclear.
For starters,
The order of wizards execution is basically the order of appearance in the dropdown since 1.6.1, the STL is described in the wizard and is available here: http://www.kisslicer.com/tuning-wizard-files.html, retraction is not there, but is described and can be easily created. Or found, I think someone once posted a link here somewhere.
We're looking for perfection! ;-)
I'm working diligently on the next Tuning Wizards Tutorial Videos - it takes time to print, photograph and do all the background work for these.
Watch the first Tutorial on the page above, it sets the stage and gets you started. The Flow Rate Wiard REQUIRES that you have your extruder (e steps) calibrated, so I am doing that calibration video first and will release the two together.
Retraction is called "Destring" in KISS and there is a Wizard for it and I'll be posting the model for Destring when I do that tutorial.
