When Short Wall (to last ext change) is selected, 1st layer starts w/ extruder 1
When Short Pillar (to last ext change) is selected, 1st layer starts w/ extruder 2
Shouldn't they be consistent w/ each other so that they both start w/ extruder 2 or vice versa?
Clicking Delete Support gives an error message that the profile cannot be deleted; however it does in fact get deleted.
inventabuild wrote:Clicking Delete Support gives an error message that the profile cannot be deleted; however it does in fact get deleted.
Which build of KISSlicer does this? I had this same problem in an earlier build, but I thought I fixed that. Could you please give me steps needed to reproduce it?
I think I've seen that message before in a build after you've said it should be fixed (don't remember the numbers, but it was a fresh build shortly after you mentioned it's fixed. But it's not reproducible, it doesn't happen every time I delete profile, not sure about inventabuild.
It's fixed in Win64 Beta4.3, I had the previously announced release 3.10...note to self always download Jonathan's latest greatest for a test drive...
voyt
Post by voyt »
Hello Jonathan,
I find the bug from older releases reapearing in 1.6 RC1 today (circular artefacts).
Here are screens.
And below the link to stl to reproduce:
https://www.dropbox.com/s/yyvpywcilupyv62/003.zip?dl=0
Some guys from other forums also were talking about poor dimensional tolerances/control for internal holes (comparing to v1.4 and 1.5), but as none of such reports finally appeared here, I guess these may have been some early user errors.
Thanks for a fantastic work!!!
It's a fun now to read other software forums endless threads about retraction finetuning ;)
euroreprap.eu
voyt wrote:Hello Jonathan,
Maybe a better two-layer view of this issue:
Here are screens.
Thank you! Could you please also attach a KISSlicer Project file? (In the menu, [Project]->[Save Project As])
Dismantled
Post by Dismantled »
Hello Jonathan,
changing the visualization per path type, extruer or material a strange pink path remain visible.
Also the colours of that path are not present in the path colour key Windows (that differ from crown path).
On mac things sometimes look like this:
Screen Shot 2017-08-18 at 21.48.59.png (21.79 KiB) Viewed 3404 times
Just parts of the text are wiped out. I don't have a way to reproduce it, just have kisslicer running for a while, slice this, slice that and then it happens.
