This is an interesting idea
https://youtu.be/HAmneiL5-jQ
Paul
Sent from my Nexus 7 using Tapatalk
Variable layer height
Re: Variable layer height
Slic3r has such option.
It works very easy - you can manually edit "heights table", for example, from Z=100mm set layer height 0.5mm, from Z=110mm set layer height 0.2mm, etc
http://manual.slic3r.org/expert-mode/va ... yer-height
Slic3r Prusa Edition has a slightly better method to do the same, but there are better ways.
