Help with quality
MedicalEngineeR
Help with quality
Post by MedicalEngineeR »
Hi everybody,
Recently i switched over to KISSlicer for better quality prints with my Cubex Duo. And what a BIG improvement. I ran 1.1 at first but recently got the 1.5 stable version. The countless settings got my head spinning like crazy, and i'm so frustrated. The print shown in the pics started out great, but then it created som holes. Almost like it spat it out of the nozzle. Any suggestions?
Holes?
Holes?
All the holes?
All the holes?
Re: Help with quality
MedicalEngineeR wrote:Hi everybody,
Did you increase the voltage on the print jet board with a sink on the driver chip ?
Are you using Cubeitmod6.05?
MedicalEngineeR
Hi Giovanni,
I'm currently running Cubeitmod6.05. But that was printet with a different version i think. I haven't increased the voltage because it is a standard hot end, and not a metallic. I saw that somewhere.
Would you recommend that?
MedicalEngineeR wrote: I'm currently running Cubeitmod6.05. But that was printet with a different version i think. I haven't increased the voltage because it is a standard hot end, and not a metallic. I saw that somewhere.
With standard hot end you can set 1.6 volts but you MUST put a sink on the chip :
http://www.geeetech.com/stepstick-heatsink-p-721.html
After you must reaclibrate the flow tweak, usually it will go down to 1 or very close to 1.
rantzaus
Post by rantzaus »
Yes
rantzaus
Post by rantzaus »
Is it possible to mount them with this?
http://www.ebay.co.uk/itm/10g-HC-910-Si ... 281d68d25a
rantzaus wrote:Is it possible to mount them with this?
I've never used silicone for this but from the description of the product it looks OK.
rantzaus
Post by rantzaus »
What did you use?
What did you use?
Thermal epoxy 2 components glue like this :
http://www.ebay.com/itm/Arctic-Silver-A ... xyXzxTH8sf
