Help with quality
Help with quality
Hi everybody,
Recently i switched over to KISSlicer for better quality prints with my Cubex Duo. And what a BIG improvement. I ran 1.1 at first but recently got the 1.5 stable version. The countless settings got my head spinning like crazy, and i'm so frustrated. The print shown in the pics started out great, but then it created som holes. Almost like it spat it out of the nozzle. Any suggestions?
- Holes?
- IMG_1025.jpeg (18.05 KiB) Viewed 5569 times
- All the holes?
- IMG_1026.jpeg (19.02 KiB) Viewed 5569 times
Re: Help with quality
Did you increase the voltage on the print jet board with a sink on the driver chip ?MedicalEngineeR wrote:Hi everybody,
Are you using Cubeitmod6.05?
Hi Giovanni,Giovanni V. wrote:Did you increase the voltage on the print jet board with a sink on the driver chip ?MedicalEngineeR wrote:Hi everybody,
I'm currently running Cubeitmod6.05. But that was printet with a different version i think. I haven't increased the voltage because it is a standard hot end, and not a metallic. I saw that somewhere.
Would you recommend that?
With standard hot end you can set 1.6 volts but you MUST put a sink on the chip :MedicalEngineeR wrote: I'm currently running Cubeitmod6.05. But that was printet with a different version i think. I haven't increased the voltage because it is a standard hot end, and not a metallic. I saw that somewhere.
http://www.geeetech.com/stepstick-heatsink-p-721.html
After you must reaclibrate the flow tweak, usually it will go down to 1 or very close to 1.
I've never used silicone for this but from the description of the product it looks OK.rantzaus wrote:Is it possible to mount them with this?
http://www.ebay.co.uk/itm/10g-HC-910-Si ... 281d68d25a
What did you use?Giovanni V. wrote:I've never used silicone for this but from the description of the product it looks OK.rantzaus wrote:Is it possible to mount them with this?
Thermal epoxy 2 components glue like this :rantzaus wrote:What did you use?Giovanni V. wrote:I've never used silicone for this but from the description of the product it looks OK.rantzaus wrote:Is it possible to mount them with this?
http://www.ebay.com/itm/Arctic-Silver-A ... xyXzxTH8sf
