Post Process Command Failed Returning -1
doc49
Post by doc49 »
I'm new Cubex Duo owner and new to Kisslicer and Cubeitmod so please bear with me. When I go to save my file
everything seems to work right except the Post Process command.
I get the error message
Can anyone tell what I'm doing wrong?
Re: Post Process Command Failed Returning -1
doc49 wrote:I'm new Cubex Duo owner and new to Kisslicer and Cubeitmod so please bear with me. When I go to save my file
the file CubeItMod605.exe is into the Kisslicer's folder?
doc49
Post by doc49 »
Yes, and in the Printer Firmware page under Post Process.
doc49 wrote:Yes, and in the Printer Firmware page under Post Process.
Do you have copied the ini files that you can find into the cubeitmod605.zip file into Kisslicer's folder ?
doc49
Post by doc49 »
Yes
doc49 wrote:Yes
Try 2 things :
1- run CubeItMod605.exe by double clicking on it, if it runs you can choose a bfb file saved with Kisslicer and it will be processed, if it works you can print.
2- Create a folder Kisslicer into the desktop, copy all the files into it and try again from this folder.
doc49
Post by doc49 »
When I ran Cubeitmod605.exe it worked.
I made new folder on my desktop and copied all the files to it and ran Kisslicer64.exe,
it gave the same error again.
I loaded the bfd file that it made when I ran Cubeitmod605.exe by itself on my USB drive
and it worked on my Cubex machine.
doc49 wrote:When I ran Cubeitmod605.exe it worked.
OK, at least you can print now.
Please post a screen shot of your Printer/Firmware tab.
doc49
Post by doc49 »
Yes, I can at least print now, thank you!
Here is my Printer/Firmware page
doc49 wrote:Yes, I can at least print now, thank you!
This looks OK.
If you run KS from a shortcut try to go into the KS folder and start KS by clicking directly on the exe file.
