Problem with retract in begin procedure
Small problem with retract filament in begin procedure. Retract length is always 1.5 mm regardless of the setting destring_suck/destring_prime.
- DDME-Marc
Re: Problem with retract in begin procedure
Have you checked that are selecting and are adjusting the correct material from your library?
In the material name tab it should show which extruder number has been assigned to your material. Double check to see if it matches Cheers,
Marc
Marc
Felix 3.0 Dual Head * E3D Titan V6 * Repetier-Host V2.0.5 * Repetier-Firmware 0.92.9 (01/08/17 - Modified) * KISSlicer Pro - 1.6.2 *
OK. If I change destring Prime/Suck mm on page Material, I must also manually edit Prefix Retract filament on Ptr G-code page. For example, destring 0.5 mm, retract filament in start procedure must be 29.5 mm.
- retract.png (11.77 KiB) Viewed 2787 times
