Help, something wrong with layers
Re: Help, something wrong with layers
For the surface you have to set the "Skin Thickness", I usually set "Skin thickness"= Extrusion width x number of loops.
About the shifting, no idea.
Pgregory
Post by Pgregory »
What are your printer maximum speed settings?
It is possible the stepper can't move that fast and is skipping steps when it resets, causing the shift.
Ros
Post by Ros »
Pgregory wrote:What are your printer maximum speed settings?
This are my specs...
Hugues
Post by Hugues »
Can you look at the x motor during a print ? Offset can came if the motor pulley is broke. An other way to see it is if your belt is going up and down while moving.
Other send your bfb.back file we will look at it.
regards,
Hugues
www.cubexupgrade.com
Ros
Post by Ros »
About the noise, check this video, you can heard some "cloncks", but I don't seem abnormal...
http://youtu.be/OzmrC1L28bQ
Checked belt tension and the pulley, seems fine.
About the back file, I edited the stl and slice it... forget to keep the trouble one.
But when I placed the model on KSS, I turned 90º to re-orient the model, maybe that can be the issue?
Ros
Post by Ros »
This is the new print and... Almost what I want... Almost...
How can I solve this holes on the surface?
Hugues
Re: Re : Help, something wrong with layers
Post by Hugues »
The "cloncks" can be done by Min jump and trigger value in the material tab. Put 15 in the two, I didn't find which one is the cause but since I put higher value i've less sound like this.
For your hole I would purpose to increase your %solid but you're at 110... Maybe increase the infill or the thickness
regards,
Hugues
Miguel_FL
Post by Miguel_FL »
Did you made the calibration cube? (Thin wall and Solid Cube).
Here you have attached the guide (How To Calibrate)
3d-printer-calibration.rar
Compiled by PenskeGuy.
(53.35 KiB) Downloaded 236 times
3DS CubeX Duo
Kisslicer Pro user
Ros
Post by Ros »
Yes I made the calibration test, all walls were ok, I'll redo the test, to be sure.
Mikk36
Post by Mikk36 »
Add more thickness to top/bottom layers and/or try lowering the temperature a bit?
