Bad printet text
rantzaus
Bad printet text
Post by rantzaus »
have printet 2 gears with text in them.. See picture
But the text is very poorly printet, Its like it did not fill the geometry... I have tried to take som pictures.
I have included my ini files, bfb, bak and STL files. Hoping someone can explain why its printet that way..
bfb, bak, stl.zip
(1.04 MiB) Downloaded 271 times
ini files.zip
(2.17 KiB) Downloaded 266 times
rantzaus
Re: Bad printet text
Post by rantzaus »
Hi Again
Im experiencing the same problem with my perimeter loops. I have taken some pictures.
I have tried to modify the ShortSolid% without any improvements.
Any Ideas?
rantzaus wrote:Hi Again
Any Ideas?
ShortSolid% affects only the SOLID path and for lengths smaller than SolidPivotLength
rantzaus wrote:have printet 2 gears with text in them.. See picture
Print letters is a real challenge for the slicer, use KS 1.5 Beta 2.20 because it has better crowning than 2.22, then change the number of loops until you find the best path.
1 Loop and 4 loops look better than 2 loops.
You also have a very low loop/solid infill overlap.
rantzaus
Post by rantzaus »
Sorry for the dump question, but where do I change the loop/infill overlap?
Printer/hardware tab
rantzaus
Post by rantzaus »
Do you have a good idea for a better number?
