First object layer on raft - bad path and/or bad infill
Olivier13
Post by Olivier13 »
Hi all
After testing several parameters, i still have bad path and/or bad infill and/or bad extrusion for the first object layer on a raft.
here is my problem :
Slicing :
https://www.dropbox.com/s/6rmdsg1e45gtb ... 4.PNG?dl=0
Result :
https://www.dropbox.com/s/un2kdw1er2h74 ... b.jpg?dl=0
Have you some idea(s)?
Regards.
Here is my G-Code (partial) :
; KISSlicer - PRO
; Windows
; version 1.5 Beta 2.22 Win64
; Built: Jun 24 2015, 08:43:36
; Running on 4 cores
; Saved: Sun Jul 12 10:05:35 2015
; '20x20x5v3_009.gcode'
; *** Printer Settings ***
; printer_name = A4v3 - 2 Extruder - Nozzle #1 #2 ready
; bed_STL_filename = C:\Program Files\kisslicer beta\a4_plate_
;     carbon.STL
; extension = gcode
; cost_per_hour = 8.9
; g_code_prefix = 3B20696E69742067636F64650A4732310A4D31303720
;     3B2066616E206F66660A4739310A4731205A320A4739300A54310A4D
;     31343020533C42454454454D503E203B20736574206265642074656D
;     7020666173740A4D31303420533C5741524D343E203B203F3F3F2070
;     72652D6865617420657874727564657220340A4D31393020533C4245
;     4454454D503E203B207761697420666F72206265642074656D702074
;     6F2072656163682074656D700A5430203B2063686F6F736520457874
;     310A4732382058300A4732382059300A473120593530204639303030
;     203B20776879206D6F76696E673F3F0A473238205A30200A4731205A
;     320A473238205930200A473120593135302046393030300A47393220
;     45300A473120583330205935302046393030300A3B205432203B2063
;     686F6F73652045787433203F3F3F0A3B204D3130342053313530203B
;     205365742045787420332020746F20313530C2B0430A5431203B2063
;     686F6F736520457874320A4D3130342053313530203B207365742045
;     78743220746F20313530C2B0430A5430203B2063686F6F7365204578
;     7431200A4D3130342053313530203B20736574204578743220746F20
;     313530C2B0430A543C4558542B303E203B2063686F6F736520657874
;     3F203F3F3F0A4D31303920533C54454D503E203B2073657420657874
;     3F20746F206D61746C2074656D700A473932204530203B2072657365
;     74206578747275646572206C656E67680A473120452D35203B20C3A0
;     20636F6D6D656E746572207369207574696C69736174696F6E203120
;     7365756C2065787472756465722073696E6F6E206C696D6974657220
;     6C6520626C6F62206465206465627574206465206C27657874727564
;     65757220320A473932204530203B2072657365742065787472756465
;     72206C656E67680A4D343030203B207761697420656E64206F66206D
;     6F76656D656E740A3B20696E69742066696E6973686564
; g_code_warm = 3B2053656C656374206E65772065787472756465720A4D
;     3430300A543C4558542B303E0A473120583C4E455854583E20593C4E
;     455854593E204636303030203B206269656E207369207574696C6973
;     6174696F6E207072696D65207374727563747572652077616C6C0A3B
;     205761726D2069742075702C20616E6420776169742074696C6C2069
;     742773207761726D0A4D31303920533C54454D503E0A3B20596F7520
;     6D61792077616E7420746F207072696D6520736F6D652066696C616D
;     656E7420686572650A47393220453C4D41544C3E203B206578747275
;     646520616D6F756E742073657420696E206D61746C2067636F64650A
;     4739322045300A473120453C4D41544C3E203B206578747275646520
;     6C656E6774682073657420696E206D61746C2067636F64650A473932
;     204530
; g_code_same_warm = 3B205761726D2069742075702C20616E642077616
;     9742074696C6C2069742773207761726D0A4D3430300A47393220453
;     00A473120452D352046323030300A4739322045300A4731203C4E455
;     854583E203C4E455854593E2046363030300A4D31303920533C54454
;     D503E0A47312045352E312046333030300A4739322045300A4D34303
;     0
; g_code_same_cool = 3B20436F6F6C2069742C206E6F206E65656420746
;     F20776169740A4D31303420533C54454D503E0A4D343030
; g_code_cool = 3B20446573656C65637420746865202873616D65292065
;     787472756465722028757375616C6C7920746F20636F6F6C290A4D31
;     303420533C54454D503E0A3B20596F75206D61792077616E7420746F
;     207265747261637420736F6D652066696C616D656E7420686572650A
;     4739322045300A473120452D3C4D41544C3E0A4739322045300A4D34
;     3030
; g_code_N_layers = 4D343030
; g_code_postfix = 4739322045300A4D313037203B207475726E2066616
;     E206F66660A3B2054330A3B204D3130342053300A3B2054320A3B204
;     D3130342053300A54310A4D3130342053300A54300A4D31303420533
;     00A4D3134302053303B205475726E206F66662068656174656420626
;     5642074656D70657261747572650A3B207061726B206578747275646
;     5720A4739310A4731205A2B31300A4739300A4731205832302059353
;     02046393030300A4732382058302059300A473120583130205931302
;     046363030300A4D3834203B2064697361626C65206D6F746F7273
; post_process = NULL
; every_N_layers = 1
; num_extruders = 2
; firmware_type = 2
; add_comments = 1
; fan_on = M106
; fan_off = M107
; fan_pwm = 1
; add_m101_g10 = 0
; z_speed_mm_per_s = 5
; z_settle_mm = 0
; bed_size_x_mm = 299
; bed_size_y_mm = 201
; bed_size_z_mm = 180
; ext_radius = 30
; bed_offset_x_mm = 149.5
; bed_offset_y_mm = 124.5
; bed_offset_z_mm = 0.15
; bed_roughness_mm = 0.1
; round_bed = 0
; travel_speed_mm_per_s = 100
; first_layer_speed_mm_per_s = 25
; dmax_per_layer_mm_per_s = 15
; xy_accel_mm_per_s_per_s = 2500
; xy_steps_per_mm = 150
; lo_speed_perim_mm_per_s = 20
; lo_speed_loops_mm_per_s = 25
; lo_speed_solid_mm_per_s = 35
; lo_speed_sparse_mm_per_s = 35
; hi_speed_perim_mm_per_s = 35
; hi_speed_loops_mm_per_s = 50
; hi_speed_solid_mm_per_s = 70
; hi_speed_sparse_mm_per_s = 70
; ext_gain_1 = 0.992
; ext_material_1 = 2
; ext_axis_1 = 0
; ext_gain_2 = 0.993
; ext_material_2 = 6
; ext_axis_2 = 0
; ext_Xoff_2 = -0.18
; ext_Yoff_2 = 0.2
; ext_gain_3 = 1
; ext_material_3 = 0
; ext_axis_3 = 0
; ext_Xoff_3 = 0
; ext_Yoff_3 = 0
; ext_gain_4 = 1
; ext_material_4 = 16
; ext_axis_4 = 0
; ext_Xoff_4 = 0
; ext_Yoff_4 = 0
; model_ext = 0
; support_ext = 1
; support_body_ext = 1
; raft_ext = 1
; ext_order_optimize = 0
; solid_loop_overlap_fraction = 1
; *** Material Settings for Extruder 1 ***
; material_name = ABS FiloAlfa-omd
; g_code_matl = 36204633353030203B206C656E67746820746F20626520
;     6578747275646520696E2073656C65637420206E6577206578742026
;     207761726D2067636F64650A4D3932205430204531303630203B20
; fan_Z_mm = 2.4
; fan_loops_percent = 100
; fan_inside_percent = 50
; fan_cool_percent = 100
; temperature_C = 235
; keep_warm_C = 225
; first_layer_C = 240
; bed_C = 110
; sec_per_C_per_C = 0.00299875
; flow_min_mm3_per_s = 1
; flow_max_mm3_per_s = 8
; destring_suck = 3.5
; destring_prime = 3.5
; destring_min_mm = 1
; destring_trigger_mm = 10
; destring_speed_mm_per_s = 50
; destring_suck_speed_mm_per_s = 50
; Z_lift_mm = 0
; min_layer_time_s = 7
; wipe_mm = 2
; cost_per_cm3 = 0.028
; flowrate_tweak = 1.03
; fiber_dia_mm = 2.81
; color = 337568512
; *** Material Settings for Extruder 2 ***
; material_name = HIPS FiloAlfa
; g_code_matl = 362046333530300A4D3932205430204531303630
; fan_Z_mm = 1.3
; keep_warm_C = 215
; first_layer_C = 245
; bed_C = 114
; Z_lift_mm = 0
; wipe_mm = 4
; flowrate_tweak = 1.04
; fiber_dia_mm = 2.85
; color = 337568512
; *** Style Settings ***
; style_name = Normal v2
; quality_percentage = 50
; layer_thickness_mm = 0.2
; extrusion_width_mm = 0.4
; num_loops = 2
; skin_thickness_mm = 0.8
; infill_extrusion_width = 0.42
; infill_density_denominator = 5
; stacked_layers = 1
; use_destring = 1
; use_wipe = 0
; use_corners = 0
; loops_insideout = 0
; infill_st_oct_rnd = 1
; inset_surface_xy_mm = 0
; seam_jitter_degrees = 0
; seam_depth_scaler = 0.1
; seam_gap_scaler = 0.2
; seam_angle_degrees = 130
; *** Support Settings ***
; support_name = Copy of CALIB - Support - Bon réglages ABS c
;     ube 20x20x5
; support_sheathe = 1
; support_density = 4
; solid_interface = 0
; support_inflate_mm = 0
; support_gap_mm = 0.4
; support_angle_deg = 55
; support_z_max_mm = -1
; sheathe_z_max_mm = -1
; raft_mode = 2
; prime_pillar_mode = 3
; raft_inflate_mm = 4
; raft_hi_stride_mm = 1
; raft_hi_thick_mm = 0.35
; raft_hi_width_mm = 0.8
; raft_lo_stride_mm = 3
; raft_lo_thick_mm = 0.5
; raft_lo_width_mm = 0.8
; brim_mm = 1.2
; brim_ht_mm = 0
; brim_fillet = 0
; interface_band_mm = 0.2
; interface_extrusion_gain = 1
; interface_Z_gap_mm = 0.04
; raft_interface_layers = 1
; *** Actual Slicing Settings As Used ***
; extrusion_width = 0.4
; num_ISOs = 2
; wall_thickness = 0.8
; infill_style = 6
; support_style = 4
; support_angle = 54.9
; stacked_infill_layers = 1
; raft_style = 2
; raft_sees_prime_paths = 1
; raft_extra_interface_layers = 1
; raft_hi_stride_mm = 1.2
; raft_lo_stride_mm = 3.2
; oversample_res_mm = 0.025
; crowning_threshold_mm = 0.8
; inflate_raft_mm = 4
; inflate_support_mm = 0
; model_support_gap_mm = 0.4
; brim_mm = 1.2
; brim_ht_mm = -0
; support_Z_max_mm = 1e+020
; sheathe_Z_max_mm = 1e+020
; seam_use_corners = 0
; skip_N_support_layers = 0
; Speed vs Quality = 0.50
; Perimeter Speed = 27.50
; Loops Speed = 37.50
; Solid Speed = 52.50
; Sparse Speed = 52.50
; *** G-code Prefix ***
; init gcode
G21
M107 ; fan off
G91
G1 Z2
G90
T1
M140 S114 ; set bed temp fast
M104 S0 ; ??? pre-heat extruder 4
M190 S114 ; wait for bed temp to reach temp
T0 ; choose Ext1
G28 X0
G28 Y0
G1 Y50 F9000 ; why moving??
G28 Z0
G1 Z2
G28 Y0
G1 Y150 F9000
G92 E0
G1 X30 Y50 F9000
; T2 ; choose Ext3 ???
; M104 S150 ; Set Ext 3  to 150°C
T1 ; choose Ext2
M104 S150 ; set Ext2 to 150°C
T0 ; choose Ext1
T1 ; choose ext? ???
M109 S245 ; set ext? to matl temp
G92 E0 ; reset extruder lengh
G1 E-5 ; à commenter si utilisation 1 seul extruder sinon limiter le blob de debut de l'extrudeur 2
M400 ; wait end of movement
; init finished
; *** Main G-code ***
; Reset extruder pos
G92 E0
; BEGIN_LAYER_RAFT z=0.75
; *** Selecting and Warming Extruder 2 to 245 C ***
; Select new extruder
M400
T1
G1 X101.84 Y64.50 F6000 ; bien si utilisation prime structure wall
; Warm it up, and wait till it's warm
M109 S245
; You may want to prime some filament here
G92 E6 F3500
M92 T0 E1060 ; extrude amount set in matl gcode
G92 E0
G1 E6 F3500
M92 T0 E1060 ; extrude length set in matl gcode
G92 E0
G92 E0
; 'Raft Path', 1.3 [feed mm/s], 16.7 [head mm/s]
G1 X101.84 Y64.5 Z0.75 E0 F6000
G1 E3.5 F3000
G1 X79.22 Y41.68 E5.9972 F1000
G1 X83.64 Y41.6 E6.3412
G1 X101.86 Y59.98 E8.3517
G1 X101.83 Y55.4 E8.7075
G1 X88.22 Y41.67 E10.2091
; 'Destring/Wipe/Jump Path', 0.0 [feed mm/s], 25.0 [head mm/s]
G1 E6.7091 F3000
G1 X101.82 Y69.03 E6.7091 F6000
G1 E10.2091 F3000
G1 X74.59 Y41.56 E13.2149 F1000
G1 X70.1 Y41.58 E13.5638
G1 X101.81 Y73.56 E17.0631
G1 X101.79 Y78.08 E17.4147
G1 X65.82 Y41.81 E21.3841
G1 X61.89 Y42.39 E21.6927
G1 X100.89 Y81.72 E25.9963
G1 X98.69 Y84.05 E26.2451
G1 X59.26 Y44.28 E30.5969
G1 X56.99 Y46.53 E30.5969 F6000
G1 X96.42 Y86.3 E34.9488 F1000
G1 X94.15 Y88.56 E35.1975
G1 X54.72 Y48.79 E39.5493
G1 X52.54 Y51.14 E39.5493 F6000
G1 X91.87 Y90.81 E43.8903 F1000
G1 X88.52 Y91.97 E44.1662
G1 X51.62 Y54.76 E48.2382
G1 X51.32 Y59 E48.5688
G1 X84.19 Y92.15 E52.1959
G1 X79.66 Y92.13 E52.5479
G1 X51.36 Y63.58 E55.6715
G1 X51.28 Y68.05 E56.0188
G1 X75.14 Y92.11 E58.6517
G1 X70.61 Y92.09 E59.0034
G1 X51.27 Y72.58 E61.1386
G1 X51.53 Y77.38 E61.5126
G1 X66.09 Y92.07 E63.1197
; Post-layer lift
G1 X66.09 Y92.07 Z1.1 E63.1197 F300
; END_LAYER_RAFT z=0.75
; *** Every 1 Layers ***
M400
G92 E0
; BEGIN_LAYER_RAFT z=1.10
; *** Cooling Same Extruder (2) to 235 C ***
; Cool it, no need to wait
M104 S235
M400
G92 E0
; 'Raft Path', 1.2 [feed mm/s], 27.5 [head mm/s]
G1 X99.82 Y71.1 Z1.1 E0 F6000
G1 X80.64 Y90.11 E1.2241 F1650
G1 X82.88 Y90.15 E1.3257
G1 X99.81 Y73.36 E2.4061
G1 X99.8 Y75.63 E2.5086
G1 X85.15 Y90.15 E3.444
G1 X87.45 Y90.12 E3.5484
G1 X99.79 Y77.89 E4.3361
G1 X99.06 Y80.87 E4.4751
G1 X90.39 Y89.46 E5.0282
; 'Destring/Wipe/Jump Path', 0.0 [feed mm/s], 40.0 [head mm/s]
G1 E1.5282 F3000
G1 X99.83 Y68.84 E1.5282 F6000
G1 E5.0282 F3000
G1 X78.36 Y90.13 E6.3986 F1650
G1 X76.1 Y90.12 E6.5012
G1 X99.82 Y66.6 E8.0154
G1 X99.85 Y64.31 E8.1189
G1 X73.85 Y90.09 E9.7781
G1 X71.57 Y90.1 E9.8816
G1 X99.86 Y62.05 E11.6873
G1 X99.85 Y59.81 E11.7889
G1 X69.31 Y90.09 E13.7382
G1 X67.04 Y90.08 E13.8408
G1 X99.88 Y57.52 E15.9365
G1 X99.8 Y55.35 E16.0352
G1 X64.87 Y89.98 E18.2647
G1 X62.99 Y89.59 E18.3516
G1 X99.29 Y53.6 E20.6682
G1 X98.73 Y51.9 E20.7493
G1 X61.31 Y89 E23.1376
G1 X59.81 Y88.24 E23.2141
G1 X98.01 Y50.37 E25.6525
G1 X97.13 Y48.98 E25.7268
G1 X58.51 Y87.27 E28.192
G1 X57.39 Y86.14 E28.2645
G1 X96.02 Y47.83 E30.7303
G1 X94.89 Y46.7 E30.8029
G1 X56.26 Y85 E33.2687
G1 X55.3 Y83.7 E33.342
G1 X93.6 Y45.73 E35.7866
G1 X92.09 Y44.97 E35.8631
G1 X54.55 Y82.18 E38.2591
G1 X53.98 Y80.5 E38.3398
G1 X90.41 Y44.38 E40.6651
G1 X88.71 Y43.81 E40.7462
G1 X53.54 Y78.69 E42.9915
G1 X53.53 Y76.44 E43.0932
G1 X86.6 Y43.65 E45.2044
G1 X84.38 Y43.6 E45.3052
G1 X53.53 Y74.18 E47.2742
G1 X53.26 Y72.2 E47.365
G1 X82.1 Y43.61 E49.2055
G1 X79.81 Y43.62 E49.3089
G1 X53.46 Y69.75 E50.991
G1 X53.32 Y67.63 E51.0871
G1 X77.59 Y43.57 E52.6363
G1 X75.31 Y43.58 E52.7398
G1 X53.29 Y65.41 E54.1452
G1 X53.32 Y63.13 E54.2487
G1 X72.79 Y43.83 E55.4911
G1 X70.8 Y43.54 E55.5819
G1 X53.35 Y60.85 E56.6959
G1 X53.32 Y58.62 E56.7967
G1 X68.26 Y43.81 E57.7502
G1 X65.99 Y43.8 E57.8527
G1 X53.5 Y56.19 E58.6504
G1 X53.79 Y53.65 E58.7665
G1 X63.41 Y44.12 E59.3803
; Post-layer lift
G1 X63.41 Y44.12 Z1.3 E59.3803 F300
; END_LAYER_RAFT z=1.10
M400
G92 E0
; BEGIN_LAYER_RAFT z=1.30
; 'Prime Pillar Path', 0.7 [feed mm/s], 37.5 [head mm/s]
G1 X78.82 Y82.6 Z1.3 E0 F6000
G1 X66.82 Y82.6 E0.2331 F2250
G1 X64.95 Y82.34 E0.2699
G1 X63.19 Y81.4 E0.3084
G1 X61.94 Y80.09 E0.3437
G1 X61.12 Y78.35 E0.3811
G1 X60.92 Y76.88 E0.4098
G1 X60.92 Y57.1 E0.7941
G1 X61.19 Y55.21 E0.8312
G1 X62.11 Y53.48 E0.8692
G1 X63.43 Y52.22 E0.9047
G1 X65.17 Y51.4 E0.9421
G1 X66.64 Y51.2 E0.9709
G1 X86.42 Y51.2 E1.3552
G1 X88.31 Y51.47 E1.3923
G1 X90.04 Y52.39 E1.4303
G1 X91.3 Y53.71 E1.4658
G1 X92.12 Y55.45 E1.5032
G1 X92.32 Y56.92 E1.5319
G1 X92.32 Y76.7 E1.9162
G1 X92.05 Y78.59 E1.9533
G1 X91.13 Y80.32 E1.9913
G1 X89.81 Y81.58 E2.0268
G1 X88.07 Y82.4 E2.0642
G1 X86.6 Y82.6 E2.093
G1 X78.82 Y82.6 E2.2442
; 'Destring/Wipe/Jump Path', 0.0 [feed mm/s], 52.5 [head mm/s]
G1 E-1.2558 F3000
G1 X68.82 Y82.6 E-1.2558 F3150
; 'Support Interface Path', 0.8 [feed mm/s], 52.5 [head mm/s]
G1 X87.73 Y68.45 E-1.2558 F6000
G1 E2.2442 F3000
G1 X82.94 Y63.62 E2.3543 F3150
G1 X86.37 Y55.71 E2.3543 F6000
G1 X87.77 Y57.13 E2.3866 F3150
G1 X87.77 Y58.26 E2.405
G1 X85.24 Y55.71 E2.4632
G1 X84.1 Y55.7 E2.4815
G1 X87.76 Y59.39 E2.5657
G1 X87.76 Y60.53 E2.584
G1 X82.97 Y55.7 E2.6941
G1 X81.84 Y55.69 E2.7124
G1 X87.76 Y61.66 E2.8484
G1 X87.75 Y62.79 E2.8667
G1 X80.71 Y55.69 E3.0286
G1 X79.58 Y55.68 E3.0469
G1 X87.75 Y63.92 E3.2347
G1 X87.74 Y65.05 E3.253
G1 X78.45 Y55.68 E3.4667
G1 X77.32 Y55.67 E3.485
G1 X87.74 Y66.18 E3.7246
G1 X87.73 Y67.31 E3.7429
G1 X76.18 Y55.67 E4.0084
G1 X75.05 Y55.66 E4.0267
G1 X82.66 Y63.33 E4.2016
G1 X87.72 Y69.58 E4.2016 F6000
G1 X73.92 Y55.66 E4.5189 F3150
G1 X72.79 Y55.65 E4.5372
G1 X87.72 Y70.71 E4.8804
G1 X87.71 Y71.84 E4.8987
G1 X71.66 Y55.65 E5.2678
G1 X70.53 Y55.64 E5.2861
G1 X87.71 Y72.97 E5.6811
G1 X87.7 Y74.1 E5.6994
G1 X69.4 Y55.64 E6.1203
G1 X68.26 Y55.63 E6.1386
G1 X87.7 Y75.23 E6.5854
G1 X87.69 Y76.36 E6.6037
G1 X67.13 Y55.63 E7.0764
G1 X66 Y55.62 E7.0948
G1 X87.69 Y77.5 E7.5934
G1 X87.12 Y78.06 E7.6063
G1 X65.43 Y56.19 E8.1049
G1 X65.43 Y57.32 E8.1232
G1 X85.99 Y78.05 E8.5959
G1 X84.86 Y78.05 E8.6142
G1 X65.42 Y58.45 E9.061
G1 X65.42 Y59.58 E9.0794
G1 X83.73 Y78.04 E9.5002
G1 X82.59 Y78.04 E9.5186
G1 X65.41 Y60.71 E9.9136
G1 X65.41 Y61.84 E9.9319
G1 X81.46 Y78.04 E10.301
G1 X80.33 Y78.03 E10.3193
G1 X65.4 Y62.98 E10.6625
G1 X65.4 Y64.11 E10.6808
G1 X79.2 Y78.03 E10.9981
G1 X78.07 Y78.02 E11.0164
G1 X65.4 Y65.24 E11.3078
G1 X65.39 Y66.37 E11.3261
G1 X76.94 Y78.02 E11.5916
G1 X75.81 Y78.01 E11.6099
G1 X65.39 Y67.5 E11.8495
G1 X65.38 Y68.63 E11.8678
G1 X74.67 Y78.01 E12.0815
G1 X73.54 Y78 E12.0998
G1 X65.38 Y69.76 E12.2876
G1 X65.37 Y70.9 E12.3059
G1 X72.41 Y78 E12.4678
G1 X71.28 Y77.99 E12.4861
G1 X65.37 Y72.03 E12.6221
G1 X65.36 Y73.16 E12.6404
G1 X70.15 Y77.99 E12.7505
G1 X69.02 Y77.98 E12.7688
G1 X65.36 Y74.29 E12.853
G1 X65.35 Y75.42 E12.8713
G1 X67.89 Y77.98 E12.9296
G1 X66.76 Y77.97 E12.9479
G1 X65.35 Y76.55 E12.9803
; Post-layer lift
G1 X65.35 Y76.55 Z1.54 E12.9803 F300
; END_LAYER_RAFT z=1.30
M400
G92 E0
; BEGIN_LAYER_OBJECT z=1.54
; fan %*255
M106 S128
; 'Prime Pillar Path', 0.5 [feed mm/s], 25.0 [head mm/s]
G1 X62.48 Y80.7 Z1.54 E0 F6000
G1 X61.37 Y79.1 E0.0377 F1500
G1 X60.93 Y77.1 E0.0776
G1 X60.92 Y76.7 E0.0854
G1 X60.92 Y57.1 E0.4661
G1 X61.19 Y55.21 E0.5032
G1 X62.11 Y53.48 E0.5412
G1 X63.43 Y52.22 E0.5767
G1 X65.17 Y51.4 E0.6141
G1 X66.64 Y51.2 E0.6429
G1 X86.42 Y51.2 E1.0272
G1 X88.31 Y51.47 E1.0643
G1 X90.04 Y52.39 E1.1023
G1 X91.3 Y53.71 E1.1378
G1 X92.12 Y55.45 E1.1752
G1 X92.32 Y56.92 E1.2039
G1 X92.32 Y76.7 E1.5882
G1 X92.05 Y78.59 E1.6253
G1 X91.13 Y80.32 E1.6633
G1 X89.81 Y81.58 E1.6988
G1 X88.07 Y82.4 E1.7362
G1 X86.6 Y82.6 E1.765
G1 X66.82 Y82.6 E2.1493
G1 X65.01 Y82.35 E2.1849
G1 X63.58 Y81.66 E2.2155
G1 X62.48 Y80.7 E2.244
G1 E-1.256 F3000
G1 X61.37 Y79.1 E-1.256 F1500
G1 X60.92 Y77.22 E-1.256
G1 X60.92 Y71.1 E-1.256
; 'Support Interface Path', 0.4 [feed mm/s], 25.0 [head mm/s]
G1 X73.5 Y61.14 E-1.256 F6000
G1 E2.244 F3000
G1 X72.81 Y61.83 E2.2599 F1500
G1 X72.95 Y62.82 E2.276
G1 X74.38 Y61.4 E2.3088
G1 X74.51 Y62.4 E2.3251
G1 X73.09 Y63.81 E2.3575
G1 X73.23 Y64.8 E2.3737
G1 X74.64 Y63.4 E2.4059
G1 X74.74 Y63.62 E2.4099
G1 X75 Y63.85 E2.4155
G1 X75.24 Y63.93 E2.4195
G1 X73.37 Y65.78 E2.4621
G1 X73.51 Y66.77 E2.4783
G1 X74.87 Y65.42 E2.5093
G1 X75.06 Y65.07 E2.5158
G1 X75.4 Y64.89 E2.5221
G1 X76.36 Y63.94 E2.544
G1 X77.69 Y64.88 E2.544 F6000
G1 X78.64 Y63.94 E2.5655 F1500
G1 X77.5 Y63.94 E2.5655 F6000
G1 X76.56 Y64.88 E2.5871 F1500
G1 E-0.9129 F3000
G1 X74.94 Y66.47 E-0.9129 F6000
G1 E2.5871 F3000
G1 X73.65 Y67.76 E2.6166 F1500
G1 X73.79 Y68.75 E2.6328
G1 X75.05 Y67.49 E2.6616
G1 X75.16 Y68.51 E2.6782
G1 X73.93 Y69.73 E2.7062
G1 X74.07 Y70.72 E2.7224
G1 X75.27 Y69.53 E2.7497
G1 X75.29 Y69.9 E2.7557
G1 X75.3 Y70.27 E2.7617
G1 X75.28 Y70.64 E2.7677
G1 X74.21 Y71.71 E2.7922
G1 X74.25 Y71.97 E2.7964
G1 X74.4 Y72.29 E2.8022
G1 X74.61 Y72.44 E2.8063
G1 X75.68 Y71.38 E2.8308
G1 X75.74 Y72.44 E2.8308 F6000
G1 X78.16 Y70.05 E2.8859 F1500
G1 X76.77 Y70.29 E2.8859 F6000
G1 X79.66 Y67.43 E2.9516 F1500
G1 X78.01 Y67.94 E2.9516 F6000
G1 X81.16 Y64.82 E3.0235 F1500
G1 X82.66 Y62.21 E3.0235 F6000
G1 X79.2 Y65.63 E3.1022 F1500
G1 X79.19 Y65.35 E3.1066
G1 X79 Y65.05 E3.1123
G1 X78.8 Y64.91 E3.1164
G1 X79.79 Y63.92 E3.1392
G1 X80.13 Y63.72 E3.1455
G1 X80.35 Y63.36 E3.1523
G1 X82.59 Y61.14 E3.2034
G1 E-0.2966 F3000
; *** Cooling Extruder 2 to 0 C and Retiring ***
; Deselect the (same) extruder (usually to cool)
M104 S0
; You may want to retract some filament here
G92 E0
G1 E-6 F3500
M92 T0 E1060
G92 E0
M400
; *** Selecting and Warming Extruder 1 to 240 C ***
M400
T0
G1 X60.70 Y78.10 F6000 ; bien si utilisation prime structure wall
M109 S240
G92 E6 F3500 ; length to be extrude in select  new ext & warm gcode
M92 T0 E1060 ;  ; extrude amount set in matl gcode
G92 E0
G1 E6 F3500 ; length to be extrude in select  new ext & warm gcode
M92 T0 E1060 ;  ; extrude length set in matl gcode
G92 E0
G92 E0
; fan off
M107
G1 X60.7 Y78.1 Z1.54 E0 F6000
G1 E3.5 F3000
G1 X60.5 Y76.5 E3.5319 F1500
G1 X60.5 Y56.9 E3.9194
G1 X60.77 Y54.87 E3.9599
G1 X61.75 Y53 E4.0015
G1 X63.14 Y51.62 E4.0404
G1 X65 Y50.66 E4.0818
G1 X67 Y50.4 E4.1216
G1 X86.6 Y50.4 E4.5091
G1 X88.63 Y50.67 E4.5496
G1 X90.5 Y51.65 E4.5912
G1 X91.88 Y53.04 E4.6301
G1 X92.84 Y54.9 E4.6715
G1 X93.1 Y56.9 E4.7113
G1 X93.1 Y76.5 E5.0988
G1 X92.83 Y78.53 E5.1393
G1 X91.85 Y80.4 E5.1809
G1 X90.46 Y81.78 E5.2198
G1 X88.6 Y82.74 E5.2612
G1 X86.6 Y83 E5.301
G1 X67 Y83 E5.6885
G1 X64.98 Y82.73 E5.7289
G1 X63.09 Y81.74 E5.771
G1 X61.81 Y80.45 E5.8068
G1 X61.11 Y79.29 E5.8337
G1 X60.7 Y78.1 E5.8586
G1 E2.3586 F3000
G1 X60.5 Y76.5 E2.3586 F1500
G1 X60.5 Y68.5 E2.3586
; 'Loop Path', 0.3 [feed mm/s], 25.0 [head mm/s]
G1 X68.37 Y77.48 E2.3586 F6000
G1 E5.8586 F3000
G1 X66.68 Y77.48 E5.8809 F1500
G1 X66.36 Y77.45 E5.8851
G1 X66.22 Y77.39 E5.8872
G1 X66.08 Y77.32 E5.8892
G1 X65.94 Y77.21 E5.8916
G1 X65.82 Y77.08 E5.8939
G1 X65.72 Y76.93 E5.8963
G1 X65.66 Y76.77 E5.8985
G1 X65.62 Y76.55 E5.9014
G1 X65.62 Y76.5 E5.9021
G1 X65.62 Y56.57 E6.1648
G1 X65.62 Y56.43 E6.1667
G1 X65.65 Y56.26 E6.1689
G1 X65.71 Y56.12 E6.171
G1 X65.78 Y55.98 E6.173
G1 X65.89 Y55.84 E6.1754
G1 X66.02 Y55.72 E6.1777
G1 X66.17 Y55.62 E6.1801
G1 X66.33 Y55.56 E6.1823
G1 X66.55 Y55.52 E6.1852
G1 X66.6 Y55.52 E6.1859
G1 X86.53 Y55.52 E6.4486
G1 X86.67 Y55.52 E6.4505
G1 X86.84 Y55.55 E6.4527
G1 X86.98 Y55.61 E6.4548
G1 X87.12 Y55.68 E6.4568
G1 X87.26 Y55.79 E6.4592
G1 X87.38 Y55.92 E6.4615
G1 X87.48 Y56.07 E6.4639
G1 X87.54 Y56.23 E6.4661
G1 X87.58 Y56.45 E6.469
G1 X87.58 Y56.5 E6.4697
G1 X87.58 Y76.43 E6.7324
G1 X87.58 Y76.57 E6.7342
G1 X87.55 Y76.74 E6.7365
G1 X87.49 Y76.88 E6.7386
G1 X87.42 Y77.02 E6.7406
G1 X87.31 Y77.16 E6.743
G1 X87.18 Y77.28 E6.7453
G1 X87.03 Y77.38 E6.7476
G1 X86.87 Y77.44 E6.7498
G1 X86.65 Y77.48 E6.7528
G1 X86.6 Y77.48 E6.7535
G1 X68.44 Y77.48 E6.9929
G1 X68.36 Y77.08 E6.9929 F6000
G1 X66.6 Y77.08 E7.0161 F1500
G1 X66.48 Y77.06 E7.0178
G1 X66.36 Y77.02 E7.0194
G1 X66.23 Y76.93 E7.0216
G1 X66.13 Y76.83 E7.0233
G1 X66.07 Y76.72 E7.025
G1 X66.03 Y76.61 E7.0265
G1 X66.02 Y76.5 E7.0281
G1 X66.02 Y56.61 E7.2902
G1 X66.02 Y56.47 E7.2921
G1 X66.04 Y56.35 E7.2937
G1 X66.1 Y56.23 E7.2954
G1 X66.17 Y56.12 E7.2971
G1 X66.27 Y56.03 E7.2988
G1 X66.38 Y55.97 E7.3005
G1 X66.49 Y55.93 E7.3021
G1 X66.6 Y55.92 E7.3036
G1 X86.49 Y55.92 E7.5657
G1 X86.63 Y55.92 E7.5676
G1 X86.75 Y55.94 E7.5692
G1 X86.87 Y56 E7.5709
G1 X86.98 Y56.07 E7.5727
G1 X87.07 Y56.17 E7.5743
G1 X87.13 Y56.28 E7.5761
G1 X87.17 Y56.39 E7.5776
G1 X87.18 Y56.5 E7.5791
G1 X87.18 Y76.39 E7.8412
G1 X87.18 Y76.53 E7.8431
G1 X87.16 Y76.65 E7.8447
G1 X87.1 Y76.77 E7.8464
G1 X87.03 Y76.88 E7.8482
G1 X86.93 Y76.97 E7.8498
G1 X86.82 Y77.03 E7.8516
G1 X86.71 Y77.07 E7.8531
G1 X86.6 Y77.08 E7.8546
G1 X68.43 Y77.08 E8.0941
G1 X68.36 Y76.68 E8.0941 F6000
G1 X66.61 Y76.68 E8.1172 F1500
G1 X66.55 Y76.67 E8.1179
G1 X66.49 Y76.63 E8.1189
G1 X66.44 Y76.57 E8.1199
G1 X66.42 Y76.49 E8.121
G1 X66.42 Y56.51 E8.3844
G1 X66.43 Y56.45 E8.3851
G1 X66.47 Y56.39 E8.3862
G1 X66.53 Y56.34 E8.3872
G1 X66.61 Y56.32 E8.3882
G1 X86.59 Y56.32 E8.6516
G1 X86.65 Y56.33 E8.6523
G1 X86.71 Y56.37 E8.6534
G1 X86.76 Y56.43 E8.6544
G1 X86.78 Y56.51 E8.6555
G1 X86.78 Y76.49 E8.9188
G1 X86.77 Y76.55 E8.9195
G1 X86.73 Y76.61 E8.9206
G1 X86.67 Y76.66 E8.9216
G1 X86.59 Y76.68 E8.9227
G1 X68.42 Y76.68 E9.1621
; 'Perimeter Path', 0.3 [feed mm/s], 25.0 [head mm/s]
G1 X68.41 Y76.26 E9.1621 F6000
G1 X68.37 Y76.28 E9.1627 F1500
G1 X66.84 Y76.28 E9.1829
G1 X66.82 Y76.27 E9.1832
G1 X66.82 Y56.74 E9.4406
G1 X66.83 Y56.72 E9.4409
G1 X86.36 Y56.72 E9.6983
G1 X86.38 Y56.73 E9.6986
G1 X86.38 Y76.26 E9.956
G1 X86.37 Y76.28 E9.9563
G1 X68.44 Y76.28 E10.1926
G1 X68.39 Y76.26 E10.1932
G1 X68.37 Y75.88 E10.1932 F6000
G1 X67.24 Y75.88 E10.2081 F1500
G1 X67.22 Y75.87 E10.2084
G1 X67.22 Y57.14 E10.4553
G1 X67.23 Y57.12 E10.4556
G1 X85.96 Y57.12 E10.7025
G1 X85.98 Y57.13 E10.7028
G1 X85.98 Y75.86 E10.9497
G1 X85.97 Y75.88 E10.95
G1 X68.43 Y75.88 E11.1811
G1 E7.6811 F3000
G1 X73.32 Y69.96 E7.6811 F6000
G1 E11.1811 F3000
G1 X73.33 Y69.91 E11.1817 F1500
G1 X71.98 Y60.37 E11.3087
G1 X71.98 Y60.31 E11.3096
G1 X72.01 Y60.24 E11.3106
G1 X72.06 Y60.18 E11.3117
G1 X72.16 Y60.13 E11.313
G1 X72.21 Y60.12 E11.3137
G1 X75.05 Y60.12 E11.3512
G1 X75.11 Y60.13 E11.352
G1 X75.19 Y60.17 E11.3531
G1 X75.24 Y60.23 E11.3542
G1 X75.27 Y60.3 E11.3552
G1 X75.61 Y62.91 E11.3899
G1 X75.63 Y62.92 E11.3902
G1 X79.74 Y62.92 E11.4444
G1 X81.12 Y60.26 E11.4838
G1 X81.16 Y60.2 E11.4848
G1 X81.23 Y60.14 E11.486
G1 X81.33 Y60.12 E11.4873
G1 X84.5 Y60.12 E11.529
G1 X84.57 Y60.14 E11.5301
G1 X84.64 Y60.19 E11.5311
G1 X84.68 Y60.25 E11.5322
G1 X84.7 Y60.33 E11.5332
G1 X84.69 Y60.42 E11.5344
G1 X84.66 Y60.47 E11.5352
G1 X77.52 Y72.93 E11.7245
G1 X77.47 Y72.99 E11.7255
G1 X77.41 Y73.03 E11.7265
G1 X77.32 Y73.06 E11.7277
G1 X73.99 Y73.06 E11.7716
G1 X73.9 Y73.05 E11.7727
G1 X73.82 Y73 E11.7741
G1 X73.77 Y72.93 E11.7751
G1 X73.76 Y72.88 E11.7758
G1 X73.34 Y69.98 E11.8145
G1 X73.32 Y69.94 E11.8151
G1 X72.94 Y69.96 E11.8151 F6000
G1 X71.58 Y60.42 E11.942 F1500
G1 X71.58 Y60.28 E11.9439
G1 X71.61 Y60.14 E11.9458
G1 X71.68 Y60.01 E11.9477
G1 X71.76 Y59.91 E11.9494
G1 X71.86 Y59.83 E11.9511
G1 X72 Y59.76 E11.9532
G1 X72.13 Y59.73 E11.955
G1 X72.2 Y59.72 E11.9559
G1 X74.98 Y59.72 E11.9926
G1 X75.22 Y59.75 E11.9958
G1 X75.35 Y59.8 E11.9976
G1 X75.45 Y59.87 E11.9992
G1 X75.54 Y59.95 E12.0007
G1 X75.61 Y60.06 E12.0024
G1 X75.65 Y60.18 E12.0041
G1 X75.67 Y60.27 E12.0054
G1 X75.96 Y62.49 E12.0349
G1 X75.96 Y62.52 E12.0352
G1 X79.48 Y62.52 E12.0816
G1 X79.5 Y62.5 E12.0819
G1 X80.78 Y60.06 E12.1182
G1 X80.85 Y59.96 E12.1199
G1 X80.94 Y59.86 E12.1216
G1 X81.04 Y59.79 E12.1232
G1 X81.14 Y59.75 E12.1247
G1 X81.31 Y59.72 E12.1269
G1 X84.53 Y59.72 E12.1693
G1 X84.76 Y59.79 E12.1725
G1 X84.87 Y59.86 E12.1742
G1 X84.95 Y59.94 E12.1757
G1 X85.03 Y60.05 E12.1775
G1 X85.08 Y60.17 E12.1792
G1 X85.1 Y60.3 E12.181
G1 X85.09 Y60.44 E12.1828
G1 X85.05 Y60.59 E12.1849
G1 X84.98 Y60.72 E12.1869
G1 X77.99 Y72.9 E12.3719
G1 X77.75 Y73.28 E12.3778
G1 X77.55 Y73.41 E12.381
G1 X77.4 Y73.45 E12.383
G1 X77.32 Y73.46 E12.3842
G1 X73.94 Y73.46 E12.4287
G1 X73.82 Y73.44 E12.4303
G1 X73.69 Y73.39 E12.4321
G1 X73.57 Y73.31 E12.434
G1 X73.48 Y73.22 E12.4357
G1 X73.41 Y73.1 E12.4375
G1 X73.36 Y72.95 E12.4396
G1 X72.95 Y70.02 E12.4786
G1 E8.9786 F3000
; 'Solid Path', 0.3 [feed mm/s], 25.0 [head mm/s]
G1 X77.34 Y73.65 E8.9786 F6000
G1 E12.4786 F3000
G1 X75.36 Y75.62 E12.5154 F1500
G1 X74.79 Y75.62 E12.5229
G1 X76.7 Y73.72 E12.5584
G1 X76.13 Y73.72 E12.5659
G1 X74.22 Y75.62 E12.6015
G1 X73.65 Y75.62 E12.6089
G1 X75.57 Y73.72 E12.6445
G1 X75 Y73.72 E12.652
G1 X73.08 Y75.62 E12.6875
G1 X72.52 Y75.62 E12.695
G1 X74.43 Y73.72 E12.7305
G1 X73.87 Y73.71 E12.7379
G1 X71.95 Y75.62 E12.7736
G1 X71.38 Y75.62 E12.7811
G1 X73.46 Y73.55 E12.8198
G1 X73.2 Y73.25 E12.8251
G1 X70.81 Y75.62 E12.8694
G1 X70.24 Y75.62 E12.8769
G1 X73.08 Y72.81 E12.9296
G1 X73.01 Y72.31 E12.9361
G1 X69.67 Y75.62 E12.998
G1 X69.11 Y75.62 E13.0055
G1 X72.94 Y71.82 E13.0767
G1 X72.87 Y71.33 E13.0832
G1 X68.54 Y75.62 E13.1636
G1 X67.97 Y75.62 E13.1711
G1 X72.8 Y70.83 E13.2607
G1 X72.73 Y70.34 E13.2673
G1 X67.48 Y75.54 E13.3647
G1 X67.48 Y74.98 E13.3721
G1 X72.66 Y69.85 E13.4682
G1 X72.59 Y69.35 E13.4748
G1 X67.48 Y74.42 E13.5696
G1 X67.48 Y73.85 E13.577
G1 X72.52 Y68.86 E13.6705
G1 X72.45 Y68.36 E13.6771
G1 X67.48 Y73.29 E13.7692
G1 X67.48 Y72.73 E13.7767
G1 X72.38 Y67.87 E13.8675
G1 X72.31 Y67.38 E13.8741
G1 X67.48 Y72.16 E13.9637
G1 X67.48 Y71.6 E13.9711
G1 X72.24 Y66.88 E14.0594
G1 X72.17 Y66.39 E14.066
G1 X67.48 Y71.04 E14.1529
G1 X67.48 Y70.47 E14.1604
G1 X72.1 Y65.9 E14.246
G1 X72.03 Y65.4 E14.2526
G1 X67.48 Y69.91 E14.337
G1 X67.48 Y69.35 E14.3444
G1 X71.96 Y64.91 E14.4275
G1 X71.89 Y64.42 E14.4341
G1 X67.48 Y68.78 E14.5158
G1 X67.48 Y68.22 E14.5232
G1 X71.81 Y63.92 E14.6037
G1 X71.74 Y63.43 E14.6103
G1 X67.48 Y67.66 E14.6894
G1 X67.48 Y67.09 E14.6968
G1 X71.67 Y62.93 E14.7747
G1 X71.6 Y62.44 E14.7813
G1 X67.48 Y66.53 E14.8578
G1 X67.48 Y65.97 E14.8652
G1 X71.53 Y61.95 E14.9405
G1 X71.46 Y61.45 E14.9471
G1 X67.48 Y65.4 E15.021
G1 X67.48 Y64.84 E15.0284
G1 X71.39 Y60.96 E15.101
G1 X71.33 Y60.46 E15.1077
G1 X67.48 Y64.28 E15.1793
G1 X67.48 Y63.71 E15.1867
G1 X73.87 Y57.38 E15.3053
G1 X73.3 Y57.38 E15.3127
G1 X67.48 Y63.15 E15.4208
G1 X67.48 Y62.59 E15.4282
G1 X72.73 Y57.38 E15.5256
G1 X72.16 Y57.38 E15.5331
G1 X67.48 Y62.02 E15.6201
G1 X67.48 Y61.46 E15.6275
G1 X71.6 Y57.38 E15.7039
G1 X71.03 Y57.38 E15.7114
G1 X67.48 Y60.9 E15.7772
G1 X67.48 Y60.33 E15.7846
G1 X70.46 Y57.38 E15.8399
G1 X69.89 Y57.38 E15.8474
G1 X67.48 Y59.77 E15.8921
G1 X67.48 Y59.21 E15.8995
G1 X69.32 Y57.38 E15.9337
G1 X68.75 Y57.38 E15.9412
G1 X67.48 Y58.64 E15.9649
G1 X67.48 Y58.08 E15.9723
G1 X68.19 Y57.38 E15.9854
G1 X67.62 Y57.38 E15.9929
G1 X67.51 Y57.49 E15.995
G1 X74.5 Y57.32 E15.995 F6000
G1 X72.33 Y59.47 E16.0351 F1500
G1 X72.9 Y59.46 E16.0427
G1 X75 Y57.38 E16.0816
G1 X75.57 Y57.38 E16.0891
G1 X73.47 Y59.46 E16.1281
G1 X74.04 Y59.46 E16.1356
G1 X76.14 Y57.38 E16.1745
G1 X76.71 Y57.38 E16.182
G1 X74.61 Y59.46 E16.221
G1 X75.17 Y59.47 E16.2283
G1 X77.28 Y57.38 E16.2675
G1 X77.84 Y57.38 E16.275
G1 X75.57 Y59.64 E16.3172
G1 X75.83 Y59.94 E16.3225
G1 X78.41 Y57.38 E16.3704
G1 X78.98 Y57.38 E16.3779
G1 X75.95 Y60.38 E16.4341
G1 X76.01 Y60.88 E16.4408
G1 X79.55 Y57.38 E16.5064
G1 X80.12 Y57.38 E16.5139
G1 X76.08 Y61.39 E16.5889
G1 X76.14 Y61.89 E16.5955
G1 X80.68 Y57.38 E16.6799
G1 X81.25 Y57.38 E16.6874
G1 X76.33 Y62.26 E16.7787
G1 X76.9 Y62.26 E16.7861
G1 X81.82 Y57.38 E16.8774
G1 X82.39 Y57.38 E16.8849
G1 X77.47 Y62.26 E16.9762
G1 X78.04 Y62.26 E16.9837
G1 X82.96 Y57.38 E17.075
G1 X83.53 Y57.38 E17.0825
G1 X81.42 Y59.47 E17.1216
G1 X81.99 Y59.46 E17.1292
G1 X84.09 Y57.38 E17.1682
G1 X84.66 Y57.38 E17.1757
G1 X82.56 Y59.46 E17.2146
G1 X83.13 Y59.46 E17.2221
G1 X85.24 Y57.37 E17.2612
G1 X85.73 Y57.45 E17.2677
G1 X83.7 Y59.46 E17.3054
G1 X84.27 Y59.46 E17.3129
G1 X85.72 Y58.02 E17.3398
G1 X85.72 Y58.58 E17.3473
G1 X84.77 Y59.52 E17.3648
G1 X85.12 Y59.74 E17.3703
G1 X85.72 Y59.15 E17.3813
G1 X85.72 Y59.71 E17.3888
G1 X85.35 Y60.08 E17.3957
G1 X85.21 Y60.78 E17.4051
G1 X85.72 Y60.27 E17.4146
G1 X85.72 Y60.84 E17.422
G1 X84.39 Y62.16 E17.4468
G1 X85.78 Y65.85 E17.4468 F6000
G1 X75.92 Y75.62 E17.6297 F1500
G1 X76.49 Y75.62 E17.6372
G1 X85.72 Y66.47 E17.8085
G1 X85.72 Y67.03 E17.8159
G1 X77.06 Y75.62 E17.9766
G1 X77.63 Y75.62 E17.9841
G1 X85.72 Y67.6 E18.1343
G1 X85.72 Y68.16 E18.1417
G1 X78.2 Y75.62 E18.2813
G1 X78.76 Y75.62 E18.2888
G1 X85.72 Y68.72 E18.4179
G1 X85.72 Y69.29 E18.4254
G1 X79.33 Y75.62 E18.5439
G1 X79.9 Y75.62 E18.5514
G1 X85.72 Y69.85 E18.6594
G1 X85.72 Y70.41 E18.6668
G1 X80.47 Y75.62 E18.7643
G1 X81.04 Y75.62 E18.7718
G1 X85.72 Y70.98 E18.8587
G1 X85.72 Y71.54 E18.8661
G1 X81.6 Y75.62 E18.9425
G1 X82.17 Y75.62 E18.95
G1 X85.72 Y72.1 E19.0158
G1 X85.72 Y72.67 E19.0233
G1 X82.74 Y75.62 E19.0785
G1 X83.31 Y75.62 E19.086
G1 X85.72 Y73.23 E19.1308
G1 X85.72 Y73.79 E19.1382
G1 X83.88 Y75.62 E19.1724
G1 X84.45 Y75.62 E19.1799
G1 X85.72 Y74.36 E19.2035
G1 X85.72 Y74.92 E19.211
G1 X85.01 Y75.62 E19.2241
G1 X85.58 Y75.62 E19.2316
G1 X85.74 Y75.47 E19.2344
G1 X78.39 Y72.61 E19.2344 F6000
G1 X85.72 Y65.34 E19.3705 F1500
G1 X85.72 Y64.78 E19.3779
G1 X79.14 Y71.31 E19.5001
G1 X79.89 Y70 E19.5001 F6000
G1 X85.72 Y64.22 E19.6083 F1500
G1 X85.72 Y63.65 E19.6157
G1 X80.64 Y68.69 E19.7101
G1 X81.39 Y67.38 E19.7101 F6000
G1 X85.72 Y63.09 E19.7904 F1500
G1 X85.72 Y62.53 E19.7979
G1 X82.14 Y66.08 E19.8644
G1 X82.89 Y64.77 E19.8644 F6000
G1 X85.72 Y61.96 E19.9169 F1500
G1 X85.72 Y61.4 E19.9244
G1 X83.64 Y63.47 E19.963
G1 E16.463 F3000
G1 X79.65 Y61.78 E16.463 F6000
G1 E19.963 F3000
G1 X79.11 Y62.32 E19.973 F1500
G1 X78.55 Y62.32 E19.9805
G1 X80.26 Y60.62 E20.0123
G1 E16.5123 F3000
G1 X75.71 Y67.78 E16.5123 F6000
G1 E20.0123 F3000
G1 X75.44 Y65.29 E20.0452 F1500
G1 X75.45 Y65.24 E20.0459
G1 X75.47 Y65.19 E20.0466
G1 X75.52 Y65.13 E20.0477
G1 X75.57 Y65.11 E20.0484
G1 X75.62 Y65.1 E20.0491
G1 X78.81 Y65.1 E20.091
G1 X78.86 Y65.1 E20.0918
G1 X78.92 Y65.14 E20.0927
G1 X78.97 Y65.2 E20.0937
G1 X78.99 Y65.26 E20.0946
G1 X78.93 Y65.45 E20.0971
G1 X76.71 Y69.63 E20.1596
G1 X76.64 Y69.77 E20.1617
G1 X76.41 Y70.28 E20.1691
G1 X76.27 Y70.69 E20.1747
G1 X76.23 Y70.75 E20.1757
G1 X76.17 Y70.79 E20.1767
G1 X76.07 Y70.8 E20.178
G1 X75.99 Y70.79 E20.179
G1 X75.94 Y70.75 E20.1799
G1 X75.9 Y70.69 E20.1809
G1 X75.88 Y70.6 E20.1821
G1 X75.91 Y70.06 E20.1893
G1 X75.89 Y69.52 E20.1964
G1 X75.71 Y67.84 E20.2186
G1 X76.13 Y67.79 E20.2186 F6000
G1 X76.1 Y67.75 E20.2192 F1500
G1 X75.87 Y65.51 E20.2489
G1 X75.89 Y65.5 E20.2492
G1 X78.44 Y65.5 E20.2828
G1 X78.43 Y65.54 E20.2834
G1 X76.55 Y69.08 E20.3362
G1 X76.37 Y68.91 E20.3394
G1 X76.35 Y68.91 E20.3397
G1 X76.24 Y69.01 E20.3416
G1 X76.11 Y67.81 E20.3575
G1 X76.13 Y67.77 E20.3581
G1 X76.5 Y67.69 E20.3581 F6000
G1 X76.31 Y65.91 E20.3818 F1500
G1 X76.32 Y65.9 E20.3819
G1 X77.77 Y65.9 E20.401
G1 X77.78 Y65.91 E20.4013
G1 X76.57 Y68.19 E20.4353
G1 X76.55 Y68.2 E20.4355
G1 X76.51 Y67.75 E20.4415
G1 E16.9415 F3000
; 'Crown Path', 0.2 [feed mm/s], 25.0 [head mm/s]
G1 X76.37 Y69.2 E16.9415 F6000
G1 E20.4415 F3000
G1 X76.3 Y69.53 E20.4443 F1500
G1 X76.3 Y69.55 E20.4444
G1 X76.2 Y70.05 E20.4486
G1 X76.17 Y70.16 E20.4496
G1 X76.09 Y70.58 E20.4531
G1 E16.9531 F3000
G1 X76.65 Y67.02 E16.9531 F6000
G1 E20.4531 F3000
G1 X77.28 Y66.39 E20.4648 F1500
G1 X76.96 Y66.14 E20.4701
G1 X76.62 Y66.48 E20.4765
G1 E16.9765 F3000
; Post-layer lift
G1 X76.62 Y66.48 Z1.74 E16.9765 F300
; END_LAYER_OBJECT z=1.54
M400
G92 E0
; BEGIN_LAYER_OBJECT z=1.74
; *** Cooling Same Extruder (1) to 235 C ***
M104 S235
M400
G92 E0
G1 X61.22 Y77.7 Z1.74 E0 F6000
G1 E3.5 F3000
G1 X61.1 Y76.63 E3.5212 F2250
G1 X61.1 Y56.9 E3.9114
G1 X61.37 Y55.01 E3.9491
G1 X62.29 Y53.28 E3.9878
G1 X63.61 Y52.02 E4.0239
G1 X65.35 Y51.2 E4.062
G1 X66.82 Y51 E4.0912
G1 X86.6 Y51 E4.4824
G1 X88.49 Y51.27 E4.5201
G1 X90.22 Y52.19 E4.5588
G1 X91.48 Y53.51 E4.5949
G1 X92.3 Y55.25 E4.633
G1 X92.5 Y56.72 E4.6623
G1 X92.5 Y76.5 E5.0534
G1 X92.23 Y78.39 E5.0911
G1 X91.31 Y80.12 E5.1298
G1 X89.99 Y81.38 E5.1659
G1 X88.25 Y82.2 E5.204
G1 X86.78 Y82.4 E5.2333
G1 X67 Y82.4 E5.6244
G1 X65.13 Y82.14 E5.6618
G1 X63.37 Y81.2 E5.7011
G1 X62.21 Y79.99 E5.7344
G1 X61.58 Y78.88 E5.7596
G1 X61.22 Y77.7 E5.7839
G1 E2.2839 F3000
G1 X61.1 Y76.63 E2.2839 F2400
G1 X61.1 Y68.1 E2.2839
; 'Perimeter Path', 0.4 [feed mm/s], 27.5 [head mm/s]
G1 X68.41 Y76.26 E2.2839 F6000
G1 E5.7839 F3000
G1 X68.37 Y76.28 E5.7845 F1650
G1 X66.84 Y76.28 E5.8047
G1 X66.82 Y76.27 E5.805
G1 X66.82 Y56.74 E6.0624
G1 X66.83 Y56.72 E6.0627
G1 X86.36 Y56.72 E6.3201
G1 X86.38 Y56.73 E6.3204
G1 X86.38 Y76.26 E6.5778
G1 X86.37 Y76.28 E6.5781
G1 X68.44 Y76.28 E6.8144
G1 X68.39 Y76.26 E6.8151
; 'Loop Path', 0.5 [feed mm/s], 37.5 [head mm/s]
G1 X68.37 Y75.88 E6.8151 F6000
G1 X67.24 Y75.88 E6.83 F2250
G1 X67.22 Y75.87 E6.8303
G1 X67.22 Y57.14 E7.0771
G1 X67.23 Y57.12 E7.0774
G1 X85.96 Y57.12 E7.3243
G1 X85.98 Y57.13 E7.3246
G1 X85.98 Y75.86 E7.5715
G1 X85.97 Y75.88 E7.5718
G1 X68.43 Y75.88 E7.8029
; 'Solid Path', 0.5 [feed mm/s], 40.0 [head mm/s]
G1 X67.46 Y75.46 E7.8029 F6000
G1 X67.57 Y75.57 E7.8049 F2400
G1 X68.18 Y75.62 E7.8129
G1 X67.48 Y74.91 E7.8259
G1 X67.48 Y74.35 E7.8334
G1 X68.74 Y75.62 E7.8571
G1 X69.31 Y75.62 E7.8645
G1 X67.48 Y73.78 E7.8987
G1 X67.48 Y73.21 E7.9062
G1 X69.87 Y75.62 E7.9509
G1 X70.43 Y75.62 E7.9584
G1 X67.48 Y72.64 E8.0136
G1 X67.48 Y72.07 E8.0211
G1 X71 Y75.62 E8.087
G1 X71.56 Y75.62 E8.0944
G1 X67.48 Y71.5 E8.1708
G1 X67.48 Y70.94 E8.1783
G1 X72.12 Y75.62 E8.2652
G1 X72.69 Y75.62 E8.2726
G1 X67.48 Y70.37 E8.3701
G1 X67.48 Y69.8 E8.3776
G1 X73.25 Y75.62 E8.4856
G1 X73.81 Y75.62 E8.493
G1 X67.48 Y69.23 E8.6115
G1 X67.48 Y68.66 E8.619
G1 X74.38 Y75.62 E8.7481
G1 X74.94 Y75.62 E8.7556
G1 X67.48 Y68.1 E8.8952
G1 X67.48 Y67.53 E8.9027
G1 X75.5 Y75.62 E9.0529
G1 X76.07 Y75.62 E9.0603
G1 X67.48 Y66.96 E9.221
G1 X67.48 Y66.39 E9.2285
G1 X76.63 Y75.62 E9.3998
G1 X77.19 Y75.62 E9.4072
G1 X67.48 Y65.82 E9.589
G1 X67.48 Y65.26 E9.5965
G1 X77.76 Y75.62 E9.7889
G1 X78.32 Y75.62 E9.7963
G1 X67.48 Y64.69 E9.9992
G1 X67.48 Y64.12 E10.0067
G1 X78.88 Y75.62 E10.2202
G1 X79.45 Y75.62 E10.2276
G1 X67.48 Y63.55 E10.4516
G1 X67.48 Y62.98 E10.4591
G1 X80.01 Y75.62 E10.6937
G1 X80.57 Y75.62 E10.7011
G1 X67.48 Y62.42 E10.9462
G1 X67.48 Y61.85 E10.9537
G1 X81.14 Y75.62 E11.2093
G1 X81.7 Y75.62 E11.2167
G1 X67.48 Y61.28 E11.4829
G1 X67.48 Y60.71 E11.4904
G1 X82.26 Y75.62 E11.7671
G1 X82.83 Y75.62 E11.7746
G1 X67.48 Y60.14 E12.0618
G1 X67.48 Y59.57 E12.0693
G1 X83.39 Y75.62 E12.3671
G1 X83.95 Y75.62 E12.3746
G1 X67.48 Y59.01 E12.6829
G1 X67.48 Y58.44 E12.6904
G1 X84.52 Y75.62 E13.0093
G1 X85.08 Y75.62 E13.0167
G1 X67.47 Y57.86 E13.3463
G1 X67.55 Y57.37 E13.3529
G1 X85.65 Y75.63 E13.6917
G1 X85.73 Y75.14 E13.6982
G1 X68.12 Y57.38 E14.0278
G1 X68.68 Y57.38 E14.0352
G1 X85.72 Y74.56 E14.3542
G1 X85.72 Y73.99 E14.3616
G1 X69.25 Y57.38 E14.67
G1 X69.81 Y57.38 E14.6774
G1 X85.72 Y73.43 E14.9753
G1 X85.72 Y72.86 E14.9827
G1 X70.37 Y57.38 E15.27
G1 X70.94 Y57.38 E15.2774
G1 X85.72 Y72.29 E15.5542
G1 X85.72 Y71.72 E15.5617
G1 X71.5 Y57.38 E15.8278
G1 X72.06 Y57.38 E15.8353
G1 X85.72 Y71.15 E16.0909
G1 X85.72 Y70.58 E16.0984
G1 X72.63 Y57.38 E16.3435
G1 X73.19 Y57.38 E16.3509
G1 X85.72 Y70.02 E16.5855
G1 X85.72 Y69.45 E16.593
G1 X73.75 Y57.38 E16.817
G1 X74.32 Y57.38 E16.8244
G1 X85.72 Y68.88 E17.0378
G1 X85.72 Y68.31 E17.0453
G1 X74.88 Y57.38 E17.2482
G1 X75.44 Y57.38 E17.2557
G1 X85.72 Y67.74 E17.448
G1 X85.72 Y67.18 E17.4555
G1 X76.01 Y57.38 E17.6374
G1 X76.57 Y57.38 E17.6448
G1 X85.72 Y66.61 E17.816
G1 X85.72 Y66.04 E17.8235
G1 X77.13 Y57.38 E17.9843
G1 X77.7 Y57.38 E17.9917
G1 X85.72 Y65.47 E18.1419
G1 X85.72 Y64.9 E18.1494
G1 X78.26 Y57.38 E18.289
G1 X78.82 Y57.38 E18.2964
G1 X85.72 Y64.34 E18.4255
G1 X85.72 Y63.77 E18.433
G1 X79.39 Y57.38 E18.5516
G1 X79.95 Y57.38 E18.559
G1 X85.72 Y63.2 E18.667
G1 X85.72 Y62.63 E18.6745
G1 X80.51 Y57.38 E18.772
G1 X81.08 Y57.38 E18.7794
G1 X85.72 Y62.06 E18.8663
G1 X85.72 Y61.5 E18.8738
G1 X81.64 Y57.38 E18.9502
G1 X82.2 Y57.38 E18.9576
G1 X85.72 Y60.93 E19.0234
G1 X85.72 Y60.36 E19.0309
G1 X82.77 Y57.38 E19.0862
G1 X83.33 Y57.38 E19.0936
G1 X85.72 Y59.79 E19.1384
G1 X85.72 Y59.22 E19.1459
G1 X83.89 Y57.38 E19.1801
G1 X84.46 Y57.38 E19.1875
G1 X85.72 Y58.65 E19.2111
G1 X85.72 Y58.09 E19.2186
G1 X85.02 Y57.38 E19.2316
G1 X85.63 Y57.43 E19.2397
G1 X85.78 Y57.58 E19.2424
G1 E15.7424 F3000
; Post-layer lift
G1 X85.78 Y57.58 Z1.94 E15.7424 F300
; END_LAYER_OBJECT z=1.74
M400
G92 E0
; BEGIN_LAYER_OBJECT z=1.94
http://www.additec.fr
PenskeGuy
Re: First object layer on raft - bad path and/or bad infill
Post by PenskeGuy »
In the KS path display, I'm not seeing the Infill paths, as-sliced. Have you run a Thin Wall and Solid Cube Calibration? It looks as if the Loop/Solid Infill Overlap value, and/or the Flow Tweak, could be adjusted; as there is a gap in places along the outside, as well as along the letter edge.
Post by Davide Ardizzoia »
Olivier,
send us your gcode (davide at 3ntr.net) we are here to help....all our customers.
Olivier13
Post by Olivier13 »
Hi Penske & Davide
PenskeGuy wrote:Have you run a Thin Wall and Solid Cube Calibration? It looks as if the Loop/Solid Infill Overlap value, and/or the Flow Tweak, could be adjusted
Yes, Flow Tweak and Gain are calibrated (and weekly checked)
For Loop/solid Infill Overlap, I will make tests with changing its value, actully set at 1.0
But...perhaps my eyes doesn't see what to see...here is the upper side of the concerned print (same as viewtopic.php?f=13&t=564 )
https://www.dropbox.com/home/KS?preview ... -layer.jpg
And external dimensions of the final print are correct with nice tolerances (certified digital caliper, average of 5 measures) :
Z height : 5mm at +0.01/+0.02mm
X/Y : 20mm at +0.08/+0.1mm
@ Davide : ok, I send it to you.
Edit : and Style\Infill is set at 16.7%
PenskeGuy wrote:In the KS path display, I'm not seeing the Infill paths
I cut it for publishing, it begin at z = 2.34
; BEGIN_LAYER_OBJECT z=2.34
G1 X68.41 Y76.26 Z2.34 E0 F6000
G1 E3.5 F3000
G1 X68.37 Y76.28 E3.5006 F1650
G1 X66.84 Y76.28 E3.5208
G1 X66.82 Y76.27 E3.5211
G1 X66.82 Y56.74 E3.7785
G1 X66.83 Y56.72 E3.7788
G1 X86.36 Y56.72 E4.0362
G1 X86.38 Y56.73 E4.0365
G1 X86.38 Y76.26 E4.2939
G1 X86.37 Y76.28 E4.2942
G1 X68.44 Y76.28 E4.5305
G1 X68.39 Y76.26 E4.5311
G1 X68.37 Y75.88 E4.5311 F6000
G1 X67.24 Y75.88 E4.546 F2250
G1 X67.22 Y75.87 E4.5464
G1 X67.22 Y57.14 E4.7932
G1 X67.23 Y57.12 E4.7935
G1 X85.96 Y57.12 E5.0404
G1 X85.98 Y57.13 E5.0407
G1 X85.98 Y75.86 E5.2876
G1 X85.97 Y75.88 E5.2879
G1 X68.43 Y75.88 E5.519
; 'Solid Path', 0.7 [feed mm/s], 52.5 [head mm/s]
G1 X72.73 Y71.46 E5.519 F6000
G1 X84.77 Y59.53 E5.7424 F3150
G1 X85.05 Y59.81 E5.7477
G1 X72.77 Y71.99 E5.9755
G1 X72.97 Y72.36 E5.9811
G1 X85.22 Y60.2 E6.2086
G1 X85.22 Y60.77 E6.216
G1 X73.05 Y72.84 E6.4419
G1 X73.25 Y73.21 E6.4475
G1 X84.78 Y61.77 E6.6616
G1 X82.18 Y59.28 E6.6616 F6000
G1 X79.62 Y61.81 E6.709 F3150
G1 X80.19 Y60.68 E6.7257
G1 X81.61 Y59.28 E6.752
G1 X83.93 Y63.18 E6.752 F6000
G1 X73.53 Y73.49 E6.945 F3150
G1 X73.9 Y73.69 E6.9505
G1 X82.94 Y64.72 E7.1183
G1 X82.37 Y65.85 E7.135
G1 X74.48 Y73.67 E7.2815
G1 X75.04 Y73.68 E7.2889
G1 X81.65 Y67.13 E7.4115
G1 X80.79 Y68.54 E7.4115 F6000
G1 X75.61 Y73.68 E7.5077 F3150
G1 X76.17 Y73.68 E7.5152
G1 X80.22 Y69.67 E7.5903
G1 X79.37 Y71.08 E7.5903 F6000
G1 X76.74 Y73.68 E7.6391 F3150
G1 X77.31 Y73.69 E7.6466
G1 X78.51 Y72.49 E7.669
G1 X72.73 Y70.9 E7.669 F6000
G1 X76.84 Y66.82 E7.7452 F3150
G1 X76.92 Y66.74 E7.7452 F6000
G1 X84.38 Y59.35 E7.8837 F3150
G1 X83.81 Y59.35 E7.8911
G1 X72.69 Y70.37 E8.0975
G1 X72.5 Y70 E8.1031
G1 X83.25 Y59.34 E8.3026
G1 X82.68 Y59.34 E8.3101
G1 X72.52 Y69.42 E8.4988
G1 X72.52 Y68.86 E8.5062
G1 X79.34 Y62.09 E8.6328
G1 X78.7 Y62.16 E8.6413
G1 X72.42 Y68.39 E8.7579
G1 X72.22 Y68.02 E8.7634
G1 X78.15 Y62.15 E8.8734
G1 X77.58 Y62.15 E8.8808
G1 X72.24 Y67.44 E8.9799
G1 X72.24 Y66.88 E8.9874
G1 X77.01 Y62.15 E9.0759
G1 X76.45 Y62.14 E9.0834
G1 X72.14 Y66.41 E9.1633
G1 X71.95 Y66.04 E9.1688
G1 X76.17 Y61.86 E9.2471
G1 X76.17 Y61.29 E9.2545
G1 X71.97 Y65.46 E9.3325
G1 X71.97 Y64.9 E9.34
G1 X76.19 Y60.71 E9.4183
G1 X75.99 Y60.34 E9.4238
G1 X71.87 Y64.43 E9.5003
G1 X71.67 Y64.06 E9.5058
G1 X75.91 Y59.86 E9.5844
G1 X75.71 Y59.49 E9.5899
G1 X71.69 Y63.48 E9.6646
G1 X71.69 Y62.91 E9.672
G1 X75.33 Y59.31 E9.7395
G1 X74.76 Y59.31 E9.7469
G1 X71.59 Y62.45 E9.8057
G1 X71.4 Y62.08 E9.8113
G1 X74.2 Y59.31 E9.8632
G1 X73.63 Y59.3 E9.8706
G1 X71.42 Y61.5 E9.9117
G1 X71.42 Y60.93 E9.9192
G1 X73.07 Y59.3 E9.9497
G1 X72.5 Y59.3 E9.9572
G1 X71.4 Y60.39 E9.9775
; 'Stacked Sparse Infill Path', 0.7 [feed mm/s], 52.5 [head mm/s]
G1 X71.33 Y60.82 E9.9775 F6000
G1 X70.4 Y60.82 E9.9904 F3150
G1 X68.98 Y62.22 E10.0181
G1 X68.97 Y65.05 E10.0572
G1 X67.55 Y66.46 E10.0849
G1 X67.41 Y66.46 E10.0868
G1 X72.12 Y66.48 E10.0868 F6000
G1 X70.38 Y66.47 E10.111 F3150
G1 X68.96 Y67.88 E10.1387
G1 X68.95 Y70.71 E10.1778
G1 X67.52 Y72.12 E10.2055
G1 X67.41 Y72.12 E10.2071
G1 X68.92 Y75.53 E10.2071 F6000
G1 X68.93 Y73.54 E10.2347 F3150
G1 X70.35 Y72.13 E10.2624
G1 X72.76 Y72.14 E10.2957
G1 X72.91 Y72.42 E10.3001
G1 X72.95 Y72.61 E10.3028
G1 X73.01 Y72.9 E10.307
G1 X73.4 Y73.47 E10.3165
G1 X74.07 Y73.77 E10.3266
G1 X74.33 Y73.75 E10.3302
G1 X74.59 Y73.76 E10.3338
G1 X74.58 Y75.55 E10.3586
G1 X80.24 Y75.57 E10.3586 F6000
G1 X80.25 Y73.59 E10.3859 F3150
G1 X81.67 Y72.18 E10.4136
G1 X84.5 Y72.19 E10.4528
G1 X85.71 Y70.99 E10.4764
G1 X78.79 Y72.17 E10.4764 F6000
G1 X78.84 Y72.17 E10.4771 F3150
G1 X80.26 Y70.76 E10.5047
G1 X80.26 Y69.58 E10.5211
G1 X80.51 Y69.33 E10.526
G1 X80.7 Y68.99 E10.5313
G1 X80.77 Y68.65 E10.5361
G1 X80.98 Y68.31 E10.5417
G1 X81.24 Y68.05 E10.5467
G1 X81.46 Y67.76 E10.5518
G1 X81.59 Y67.44 E10.5567
G1 X81.7 Y67.03 E10.5624
G1 X82.21 Y66.52 E10.5724
G1 X84.52 Y66.53 E10.6044
G1 X85.72 Y65.34 E10.6278
G1 X80.32 Y57.46 E10.6278 F6000
G1 X80.31 Y59.44 E10.6554 F3150
G1 X78.89 Y60.85 E10.683
G1 X76.26 Y60.84 E10.7194
G1 X74.65 Y59.22 E10.7194 F6000
G1 X74.66 Y57.44 E10.7441 F3150
G1 X74.28 Y57.42 E10.7493
G1 X73.9 Y57.42 E10.7545
G1 X73.53 Y57.44 E10.7597
G1 X73.15 Y57.42 E10.765
G1 X72.77 Y57.42 E10.7702
G1 X72.4 Y57.43 E10.7754
G1 X72.02 Y57.42 E10.7806
G1 X71.64 Y57.42 E10.7858
G1 X71.26 Y57.43 E10.7911
G1 X70.89 Y57.41 E10.7963
G1 X70.51 Y57.41 E10.8015
G1 X70.13 Y57.43 E10.8067
G1 X69.76 Y57.41 E10.8119
G1 X69.38 Y57.41 E10.8172
G1 X69 Y57.42 E10.8224
G1 X68.99 Y59.4 E10.8497
G1 X67.57 Y60.8 E10.8774
G1 X67.42 Y60.8 E10.8795
G1 E7.3795 F3000
; Post-layer lift
G1 X67.42 Y60.8 Z2.54 E7.3795 F300
; END_LAYER_OBJECT z=2.34
PenskeGuy
Post by PenskeGuy »
I said: "in the KS path display". I don't want to look at the G-code, I want to see what KS is doing with its paths at those letter borders.
Olivier13
Post by Olivier13 »
Here is a pics of the concerned layer :
https://www.dropbox.com/home/KS?preview=Layer4.PNG
PenskeGuy
Post by PenskeGuy »
Well, for whatever reason, I can't get to your Dropbox. Can you not just post it using this forum's attachments ability?
Olivier13
Post by Olivier13 »
Hello
Here is pictures.
PenskeGuy
Post by PenskeGuy »
Olivier13 wrote:Hello
Here is pictures.
Ooooookaaaay... same images as the first set. I would like to see the layers above the first, the ones that show the Infill paths that go in between the Perimeter and the letter.
Olivier13
Post by Olivier13 »
PenskeGuy wrote:I would like to see the layers above the first
The extrusion height of the letter is same as layer height, it's just a "complete" solid infill layer :
I made a test with 0,3mm layer thickness :
Result :
Here is another print :
I have observed the print process and, I can clearly say, only for first layer parts, that :
1. the infill path seems "too short" at 180° corners (even loop/solid Infill Overlap set to 1)
2. while printing, sometimes, the nozzle "stop/do 180° corner" before reach/overlap the internal loop perimeter.
For 1 : In Style tab, KS should propose a parameter which will increase the first layer infill path length at 180° corner of a coefficient/multiplication of extrusion width.
For 2 : I have no idea.
