fill/perimeter
LTM14
fill/perimeter
Post by LTM14 »
Hi, in the first layer, the fill does not touch the perimeter, kisslicer can solve the problem?
jonny.m
Re: fill/perimeter
Post by jonny.m »
Hi LTM14,
You could try to further reduce the "1st Layer Max Speed". But most likely your Z-Gap is to big. Adjust it on the printer or use the Z Offset in Kisslicer (Printer Tab). Either ways be carefull when adjusting it.
Regards,
Tobi
PenskeGuy
Re: fill/perimeter
Post by PenskeGuy »
Have you calibrated KS to your printer?
Did you adjust the Loop/Solid Infill Overlap?
LTM14
Re: fill/perimeter
Post by LTM14 »
I solved, the problem is the setting of the firmware, it was set to "5D-related E", instead my printer is "absolute 5D-E" ... thanks
PenskeGuy
Re: fill/perimeter
Post by PenskeGuy »
OK. Thanks for reporting back.
