fill/perimeter
fill/perimeter
Hi, in the first layer, the fill does not touch the perimeter, kisslicer can solve the problem?
- IMG_0019.jpg (24.38 KiB) Viewed 3287 times
Re: fill/perimeter
Hi LTM14,
You could try to further reduce the "1st Layer Max Speed". But most likely your Z-Gap is to big. Adjust it on the printer or use the Z Offset in Kisslicer (Printer Tab). Either ways be carefull when adjusting it.
Regards,
Tobi
Regards,
Tobi
- PenskeGuy
Re: fill/perimeter
Have you calibrated KS to your printer?
Did you adjust the Loop/Solid Infill Overlap?
Re: fill/perimeter
I solved, the problem is the setting of the firmware, it was set to "5D-related E", instead my printer is "absolute 5D-E" ... thanks
- PenskeGuy
Re: fill/perimeter
OK. Thanks for reporting back.
