Stl file of the print plan
I wanted to draw the print plane of my printers with solidworks but I find it difficult to understand how to build it or I don't understand how kisslicer receives the file and from which coordinate it positions the drawing, I tried to use the front work plane in solidworks but even if I invert the extrusion places the plane always above the print level, where am I going wrong? the arrow with the circle indicates the thickness of the stl model, basically the top of the stl model should be aligned with the second arrow the one on the right.
- bed_stl.png (160.14 KiB) Viewed 12199 times
Re: Stl file of the print plan
Hi.
I have attached a copy of the Prusa Mk2 heatbed. This may help you to come up with a model for your printer.
- Heatbed-MK42.zip
- (50.33 KiB) Downloaded 643 times
Thanks Peter, I share the Ultimaker and Flsun sr Print Bed with the community, I hope it will be useful for those who use Kisslicer.
p.s. In the file relating to the bed of the Flsun printer, the X and Y coordinates for the centering of the Kisslicer plane are indicated
- BED_FLSUN_SR_X192Y130.zip
- (419.49 KiB) Downloaded 624 times
- Bed_FLSun_sr.png (91.04 KiB) Viewed 12175 times
Ultimaker
- Bed_Ultimaker.png (129.03 KiB) Viewed 12172 times
- BED_ULTIMAKER_2+.zip
- (841.01 KiB) Downloaded 614 times
