Display a line in 3D for the seam angle if changing it...
frankjoke
Post by frankjoke »
That is actually the only other feature request I would have!
The Angle selection for the seam hiding is a very small dial (and you cannot enter absolute angles).
Depending how parts are placed I want sometimes to 'hide' the seam in a corner or on the back of the print.
But you need to turn the angle, then slice, then look up where the seam is.
Why cant you just display a bigger pointer over the models showing which direction you have currently selected (see below example):
SeamHidingAngle
SeamHidingAngle
p.s.: Another option is the ability to select next inner or outer corner (the picture above is an outer corner) instead the angle.
PenskeGuy
Re: Display a line in 3D for the seam angle if changing it..
Post by PenskeGuy »
frankjoke wrote:Why cant you just display a bigger pointer over the models showing which direction you have currently selected (see below example):
Probably can. It evidently seems easy to you. It isn't. It takes is someone to develop the code to do it and that code just might be complex.
