Bottom and top stepover settings
Tinchus2009
Post by Tinchus2009 »
Hello all.
Can someone explain me how exactly these 2 options work?
Thnaks in advance
Re: Bottom and top stepover settings
Bottom stepover is the maximum amount of overhang (in percentage of extrusion width) when the model is expanding out.
Top stepover is the same, but when the model is getting smaller.
The layer height will be adjusted to get as close to these values as possible, but is limited by the (minimum) Layer Thickness and Max Layer Thickness settings (Layer Control setting).
In the latest version(s), the First Layer setting is a fixed value. Not sure if the ToolTips user the term "overhang" - if not it has been changed to this on the next release (I am using 23.07 rc).
dadoblu_2000
Post by dadoblu_2000 »
@pjr when do you expect the new version 23.07 will be available?
dadoblu_2000 wrote: 30 Aug 2023, 05:37 @pjr when do you expect the new version 23.07 will be available?
Hopefully this weekend.
