Please note that these profiles have been created using the latest (beta) firmware.
Although the profiles have been tested and work well for me, please use them with care and understand that they are supplied for use at your own risk.
IMPORTANT NOTE: In order for these profiles to work, you will need to download and use the very latest version of Kisslicer (currently 23/03) which will be released in the next few days. DO NOT attempt to use these profiles with Kisslicer version 22.11 or earlier.
The Prusa Mk3 firmware now correctly implements arcs (G2/G3) and these profiles are set to use arcs whenever possible. The Kisslicer arc generation works very well and allows models created using simple design software (i.e. Tinkercad) to be printed with smooth cylinders, rather than faceted sides.
WARNING: The Prefix G-code contains 4 lines which tweak the load and unload speeds and also the pulley current. If you don't want to change these settings, please remove those lines.
Note that these profiles were uploaded before the MMU3 was announced, so still retain the "MMU2S" label. They are currently being used on a Mk3S/+ with MMU3 from the beta test.
Prusa Mk3 + MMU3 Profiles
- Kisslicer Prusa Mk3 + MMU2SR Profiles.zip
- (26.5 KiB) Downloaded 447 times
