Hello,
I am running into bigger issues with my production run's for parts that I do need to print the same part multiple times and spacing them on the bed doesn't allow me to place them individual on the bed as needed. The auto placement always turns the 2nd part 90 degrees and I am never able to just rotate a part correctly. Even if I load 2 times the same stl file it turn's only 1 part and never the 2nd which is 90degree's turned in the wrong direction.
Please reach out to me so we can test and develop this fix.
Attached is a example and it doens't matter if I load it once and than up the count or load it twice it never allows me to rotate the 2nd part which in this picture is on the left side.
individual part rotation
- Kisslicer 2 part rotation issue.jpg (245.72 KiB) Viewed 8448 times
