Why is this happening?
Cameluntu
Post by Cameluntu »
A word is worth a thousand words.
Why am i getting this?Or at least what should i check? I have looked everywhere, seam is in the middle section. I have tried preload = to 6 and = to 0.75 (for science) and i get similar results.
Thank you in advance for any help!!!
ksh_germany
Re: Why is this happening?
Post by ksh_germany »
Hello,
i think it will come from wipe or Unload Setting you're using alpha 1.6.3?
because there is an issue with unload Settings, take a look viewtopic.php?f=5&t=4744&start=10#p10602
Cameluntu
Post by Cameluntu »
Thanks for your reply! However i have tried disabling unload and wipe, results are similar. I'll download v1 and see if i get the same issue.
ksh_germany
Please send gcode, for Research.
Cameluntu
Post by Cameluntu »
This is the very last one with unload set to 50mm, i would need to print another one without unload if you want to dive into it.
NuovoKisslicer.rar
(1.98 MiB) Downloaded 229 times
Cameluntu
Post by Cameluntu »
i think i found the issue comparing my different printers. PreloadVE and Linear Advance dont like each other (probably for obvious reasons), disabling PVE would not generate the issues above.
Cameluntu
Post by Cameluntu »
Apparently it's not even that, so gl kisslicer and welcome prusa slicer . Cheers
ksh_germany
:shock: nice to know thanks for telling your experience
