Calibrate extrusion multiplier before preload ve wizard?
Title mostly sums it up. I didn’t know if it’s necessary to calibrate the extrusion multiplier prior to running any of the wizards.....specifically the preload wizard.
- ksh_germany
Re: Calibrate extrusion multiplier before preload ve wizard?
No it is necessary, but if your print have blobs or gap in the Z seam you will have to run some Wizards most Temperaturen and Flow will helps at start to bring good print. Preload is like a Software linear advance, See as a topping on a Muffin Not necessary but makes life sweeter.
I'm having issues with preload. every time I run the test I see about 1.6 preload as the best section of the test model. however, after printing some actual things, the seam is absent of filament for a bit, after the seam. I have about 800mm of drive length and others with similar setups tell me that 1.6 preload sounds really high.
- ksh_germany
PreloadVE is in µS[microseconds] that's 1 Microseconds = 0.000001 Seconds! So a Preload of 1.6µS( 1.6 Microseconds = 0.0000016 Seconds) is not really high. 800mm Drive length is high. So i think there is no Problem.
Unfortunately, despite 1.6 looking adequate for the test model in the wizard, it yielded a seam lacking filament on the trailing side (the start of the layer). Thoughts?
- ksh_germany
Possible seam gap and seam depth and wipe settings have to get some "tune".
Possibly, but it was a decent “tear” roughly 1mm or so post the seam.
- ksh_germany
this is a "blob" then you have to increase the wipe distance.
Does it perform a wipe at the seam? I’ve watched for it, but don’t see it happening.
- ksh_germany
The "wipe" is an irritating Word. IT meams every time when the extruder Motor stops there is some pressure in/on the filament that want out ( aka oozing). The wipe setting should wipe(use) the ooze to fill that zgap. But to Do this kisslicer must know how much/long the ooze is. So you have to Set the Z gap and the wipe length and voila no gaps
