fill/perimeter
Posted: 07 Apr 2015, 05:20
by LTM14
Hi, in the first layer, the fill does not touch the perimeter, kisslicer can solve the problem?
Re: fill/perimeter
Posted: 07 Apr 2015, 14:20
by jonny.m
Hi LTM14,
You could try to further reduce the "1st Layer Max Speed". But most likely your Z-Gap is to big. Adjust it on the printer or use the Z Offset in Kisslicer (Printer Tab). Either ways be carefull when adjusting it.
Regards,
Tobi
Re: fill/perimeter
Posted: 07 Apr 2015, 19:00
by PenskeGuy
Have you calibrated KS to your printer?
Did you adjust the Loop/Solid Infill Overlap?
Re: fill/perimeter
Posted: 08 Apr 2015, 02:59
by LTM14
I solved, the problem is the setting of the firmware, it was set to "5D-related E", instead my printer is "absolute 5D-E" ... thanks
Re: fill/perimeter
Posted: 09 Apr 2015, 04:10
by PenskeGuy
OK. Thanks for reporting back.
