I need to use KS because it is the only slicer that allows me to hide the path start/ends by placing them in an internal curve, but it is giving me odd results: reproducible blivets that protrude near the top and bottom of the piece. (see picture)
The image shows several of my tests - the one on the left is from Cura, the rest are KS. Each of the KS pieces has three distinct blobs where the head pauses briefly and squirts a blob. Also near the top of the piece there are slight bulges at the start/end points, and near the bottom in the first half-dozen layers there are also blobs being created.
The blobs are not in the model, and occur with versions of KS beta back to the Sept 14 version. The model does not show any errors that could cause the issue, and nothing odd is visible in the Paths view in KS.
Even changing the layer height still produces the blobs in the same places. I've tried every combination of settings I can think of, and spent the last two days trying to get rid of the raspberries - when I change settings, they sometimes move around a bit, but they don't go away.
I've attached the .stl and the gcode showing my settings in the hope that someone can help (unzip the files after download). Bug or Not?
https://dl.dropboxusercontent.com/u/338 ... ng.stl.zip
https://dl.dropboxusercontent.com/u/338 ... .gcode.zip
