Accuracy Settings
hittinbottom
Accuracy Settings
Post by hittinbottom »
I have a second gen cube and have kisslicer printing really well. The only problem I have is the accuracy overall. It seems to print objects a little smaller than they are designed. If I print the same file with the cube software they are about right on the money. Anybody have any ideas on what to change that might help? Thanks.
hittinbottom
Re: Accuracy Settings
Anyone?
Pgregory
Post by Pgregory »
To my knowledge, there is no scaling feature in KISSlicer.
You will have to scale your project in your designer before you export the STL file.
DDME-Marc
Post by DDME-Marc »
Hello,
Scaling in KISSlicer can be done at the STL model pane, by simply adjusting the height value in proportion to your requirements. In doing so your model will rescale (and is very visible when large changes are made), and changes are indicated in percentage above.
Cheers,
Marc
Felix 3.0 Dual Head * E3D Titan V6 * Repetier-Host V2.0.5 * Repetier-Firmware 0.92.9 (01/08/17 - Modified) * KISSlicer Pro - 1.6.2 *
Mikk36
Post by Mikk36 »
There's also a right-click menu there.
