Page 1 of 3
What does this message mean?
Posted: 19 Jan 2015, 06:58
by Miatpi
Hi, I want to print a model with a cubex printer but when I save my bfb CubeItmod gives me this message: "According to fit the lowest Cubex RMP some X/Y speeds are increased by 900%". What does it mean? Is it crucial for my print?
Re: What does this message mean?
Posted: 19 Jan 2015, 07:38
by Hugues
It's the repport of cubeitmob modifications. 900% is really hight !
To decrease this try remove the min layer time with "0" and use a prime pillar.
Posted: 19 Jan 2015, 09:10
by Miatpi
Hugues wrote:Hi,
I can“t find the "min layer time" setting. Also I wonder if these M227/M228 settings are involved in this problem.
Posted: 19 Jan 2015, 09:15
by Hugues
No, there is no relation with m227/m228.
The min layer time boxe is in the material tab/ fan cool section/ Min Layer [s]
Check if there is a value inside it.
Posted: 19 Jan 2015, 09:17
by Miatpi
Hugues wrote:No, there is no relation with m227/m228.
Ah, it's there. I was searching in the Printer/speed settings. What should I set it to, 20 s?
Posted: 19 Jan 2015, 09:18
by Hugues
No, set 0 and if your model need to be cool down, put a prime pillar
Posted: 19 Jan 2015, 09:22
by Miatpi
Hugues wrote:No, set 0 and if your model need to be cool down, put a prime pillar
Thanks, but I wonder why I shouldn't that option. Wouldn't the layers slow down using it?
Posted: 19 Jan 2015, 09:32
by Hugues
Cubeitmod adapt the speed to the RPM readable by the cubex. When you activate this function Kisslicer may calculate a really slow RPM and as Cubeitmod convert them in a readable value it increase the speed. It could be (like your case) too much.
The cubex cannot go down 0.1 rpm.
Posted: 19 Jan 2015, 09:42
by Miatpi
Thanks for the help, the error is gone now. Now I still have a problem: my printer is to quick with the printing so my model is prety rough. I have set it to be very precise but it's prints as quick as always. Any thoughts?
Posted: 19 Jan 2015, 10:01
by Hugues
Set all speed to 25, it will be good to have a precise print.
