Remove Restrict Advanced Settings
Hi, how remove "restrict advanced settings" ask me for password and is very annoying, please.
- ksh_germany
Re: Remove Restrict Advanced Settings
Hi, that is a "production" Setting, if you set a Password the advanced Settings will be locked.
The effect is when you set a Password you can't switch between settingslevels it is for "production" to keep Settings safe for unwanted interventions by other users
Greetings from Germany
Beantworte fragen zu Kisslicer auf deutsch
Yes, I need remove the password.
- ksh_germany
No Problem, you must edit kisslicer.prefs. you'll find it @ C:\Users\*YOU WINDOWS USERNAME*\AppData\Roaming\lonesock Software\
Thank you very much!!!ksh_germany wrote:No Problem, you must edit kisslicer.prefs. you'll find it @ C:\Users\*YOU WINDOWS USERNAME*\AppData\Roaming\lonesock Software\
