Calculations in gcode and other suggestions
e-Mole
Post by e-Mole »
First thanks for great slicer! I want to give some suggestion:
1) For a mixing extruder, a gradient could be easily generated using <%> - something like
M165 A<(100 - %) / 100> B<% / 100>
in N layers gcode section. It would be necessary to allow multiplying, dividing and brackets in material gcode section.
2) The mixing extruder is limited to 4 extruders only. To use the full potential of the mixing extruder, something like a "virtual extruder" could be useful - where different materials could be assigned to different meshes like a classic extruder (mixing ratio would be then set in the material gcode).
3) For primming extruder with different colors would be nice to print into printed object (as infill, or something else...)
Re: Calculations in gcode and other suggestions
Hi and thanks for the suggestions.
The extruder count will be increased significantly in V2 final and purging into infill is already on the feature request list.
Not sure whether calculations will be possible withing tokens; only the very simplest math is currently allowed :( but I will add it anyway.
