Page 1 of 2
Surface texture wizard?
Posted: 10 Aug 2018, 09:07
by frozen.rabbit
What is it? what does it do? Have registered version of KS, says it's a Premium feature, but loads the interface.
Re: Surface texture wizard?
Posted: 10 Aug 2018, 17:16
You load a grey scale image (or create a random-ish bitmap) and that is then "printed" on vertical walls.
It's possible to scale the image; it's "printed" by varying the extrusion of the perimeter (perimeter must be printed after loops).
I tested it on a 2 cm cube with my avatar; I was very pleased with the result, but it's probably not something I would use all the time.
Posted: 10 Aug 2018, 17:39
by frozen.rabbit
I thought it might be something like velocity painting.
Posted: 11 Aug 2018, 08:33
by MacBain68
pjr wrote:I tested it on a 2 cm cube with my avatar; I was very pleased with the result
Can you post a picture of this test cube?
Posted: 11 Aug 2018, 16:39
MacBain68 wrote:Can you post a picture of this test cube?
I looked for the photo earlier, but couldn't find it.. Then I had a thought. It was still on my phone
Please note that these are very early tests, so do not show up as well as with later KISS versions.
- Random noise bitmap
- Avatar. Note that it's reversed and repeated around the cube starting from the centre of the side.
Posted: 19 Oct 2018, 08:42
by Sue3DDesigns
Hi Peter,
This looks great.
I have been playing with this on the Alpha (Premium) for the past few days, and no matter what I do, I cannot get it to apply anything to the finished objects.
I have tried it on objects with curved and flat surfaces.
I've tried -
Noise only
Image only
0, 50, 100% blend
Scale of both from 1 to 100mm
0 to 100% strength
Sharpen from 0 to 5
Even tried the "Only Enclosing Perimeters" option - nothing.
I get lovely prints, but no texturing is applied.
Nothing seems to make a difference despite there being a really high contrast image in the right hand pane.
Is there a setting somewhere that needs flipping to turn it on?
I know this is an Alpha, but as KS is so complex, I suspect I'm just being dumb. Any ideas?
I can supply screenshots of settings, etc., if required.
Thanks,
Susi.
Posted: 19 Oct 2018, 13:39
Sue3DDesigns wrote:Hi Peter,
This looks great.
I've tried -
Noise only
Image only
0, 50, 100% blend
0 to 100% strength
Sharpen from 0 to 5
Thanks,
Susi.
Hi Susi
It's been a long time since I did those prints (I think it was using 1.63 alpha/test version), I can't remember just what I did; all I know is that it just worked.
I will have a look to remind myself and get back to you.
Posted: 19 Oct 2018, 13:49
Susi
It's the "Strength" setting. For me, when I set the strength > 0, all the windows turn bright magenta and I get the pattern on the output G-code.
I use Craftware to view the G-code (the texture is not displayed in KISS):
This is with 100% Strength. I will print it out to see the finished result.
Posted: 19 Oct 2018, 13:56
Here the settings:
Texture Wizard:
Style:
- Image2.png (25.3 KiB) Viewed 4670 times
Loop1 must be before Perimeter; the perimeter has additional material extruded, so it must have a loop to prevent inward extrusion.
Posted: 19 Oct 2018, 14:34
by hacker
Interesting. I didn't realize it's done by increasing extrusion, I thought it actually changes perimeter path. That would be more complex, probably more effective, but definitely less interesting. Still haven't tried it.
