Wizards for gap and seam.
Would be nice if we could have a wizard for setting up and testing value ranges for things that make kiss unique like the gap seam and depth. I’m sure I can think of other wizard too but anything that might be meaningful to run thru a wizard would be awesome.
Re: Wizards for gap and seam.
+1*10^googolplex
You have no idea how many times I have asked for this.
As I'm just starting on my KISSlicer journey (and have watched Michael's videos), where could I start with gap and seam settings? Is there a recommended STL for testing these settings. However, presumably they are dependent on filament, and several other settings.
I started with both at zero. Then I played around with the settings (one at a time) too see if I could get any improvement.garis wrote:As I'm just starting on my KISSlicer journey (and have watched Michael's videos), where could I start with gap and seam settings? Is there a recommended STL for testing these settings. However, presumably they are dependent on filament, and several other settings.
After slicing, you can look at the "Paths" view to see the differences.
May I ask what you wound up with? I'm all over the place, and always seem to wind up where I started. Having a target range to go with initially would definitely help.pjr wrote:garis wrote:[...] I started with both at zero. Then I played around with the settings (one at a time) too see if I could get any improvement.
So far, Seam Depth 0.1, Seam Gap 0.1 and Join-Loop set to Seam seems to be helping the most. I've got Loop-Order set to Perimeter-Last.
Has anyone got a link to pics with settings & results? Once I have a feel for what each setting changes, I'm sure this will get much easier.
Thanks!
I am currently running depth at 0.5 and gap 0.0.
But I am not currently printing anything important; just testing for some printer company at the moment
so my seams are not particularly well hidden.
We really do need a wizard for this.
