Hello.
Just started to use kisslicer. And faced a problem right from the start: after i load the g-code to the printer, it starts to move the nozzle, but the stepper that is supposed to push the ABS thrue the nozzle is not moving, so the nozzle is just floating in the air without printing (the stepper is OK, i tested it using CURA).
Did anyone faced the problem? Tried to search, but didn't found anything on the forum.
P.S.: sorry for my english.
Thank you.
no fillament extrusion
Re: no fillament extrusion
i figured it out. under printed gcode settings in prefix there is a line that sets extruder in absolute or relative mode. that should be in relative M83. this fixed the issue for me
