Ext0 For Printing / Ext1 for Infill?
Is there a way to tell KISSlicer to use Ext0 for printing and Ext1 for Infill?
- EddyMI3D
Re: Ext0 For Printing / Ext1 for Infill?
Hello inventabuild!
Have a loot at the Ext Map tab.
In the lower right there ia an area called Default Extruder Mapping. Here you can set up this stuff...
Eddy
Eddy
Yeah, but it doesn't have the "infill" option.
I will add it to feature requests.
- EddyMI3D
Yap - silly me
I mixed up infill and support...
- Olivier13
Hi
+1 for this new feature!!
With your idea :
In Style Tab, add a "Num Infill Loop" option :
with this...let's go for composite parts !!
Olivier
With your idea :
- extrusion width : like Infill
- by default = 0, to infinite
- if you set a number, this will add the desired number of internal loop to "Num Loop"
Olivier
http://www.additec.fr
