KISSlicer 1.6 Beta Feature Requests
Posted: 28 Jun 2017, 12:28
PLEASE PLACE ALL FEATURE REQUESTS IN THIS THREAD
I will then summarise them for Jonathan
Thanks in advance
Ability to change the inset offset for outer perimeters and inner perimeters (holes) separatelyMcNugget6750
Add bridge detection - lay down a series of parallel lines over the gap McNugget6750
An option to reduce the extrusion amount on the first layer of bridges to keep the bridges from sagging McNugget6750
Separate fixed layer height for supports (except for interface) pjr
Ability to select a different extruder for infill inventabuild
Style setting for each extruder when each extruder has different nozzle size inventabuild Olivier13
Separate setting for prime pillar diameter Olivier13
Separate settings for destring Prime & Suck (speed/length) Olivier13
Raft - where the models have holes in the base, a setting to fill the holes in the raft Olivier13
Include loaded STL files in project file funBart
Option to display non-printing moves when viewing models/paths or paths funBart
Waste tower rather than Prime Pillar for SNMM printers StrannikZet
Definable angle of solid infill inventabuild
support for Ultimaker 3 Griffin Gcode style and maybe also Ultigcode (cjs)
Option to "avoid crossing perimeters" during a move (Inventabuild)
select the order in which KISSlicer starts printing the parts (Inventabuild)
Brim - also apply to internal first layer voids Olivier13
Brim for support bed interface frozen-rabbit & others
Support material flow gain frozen-rabbit
User-defined mouse button actions (or at least reversal) xmas75
Spiral vase mode Ronin
Detect sections of G-Code with constant retract/prime (which lead to blockages) and amend Voyt
Pillar options : allow user to choose if Single or Double pillar per extruder (Olivier13)
Preheat suggestions (inc Max Preheat Time for matls which may burn) Beefeater)
Thanks in advance
