Cubeitmod V4.9
Matt W
Cubeitmod V4.9
Post by Matt W »
I tried several times to replacing Cubeitmod V4.8 with V4.9 and had no luck. Tried the new .ini files and my old .ini files and same with the .au3 file, the .po file, CubeItMod.exe and CubeItMod491.exe all posted on Refugee Camp forum. I keep getting the same result below. Not sure what I'm doing wrong cause V4.8 works terrific. Any help would be appreciated. Running Win7, KISSlicer64_1.4.5.5 with Pro license.
Settings
Settings
Error Message
Error Message
plexus
Site Admin
Re: Cubeitmod V4.9
Post by plexus »
Moved topic from "forum talk" as this is not related to discussing the forum but is a troubleshooting post.
Please make sure you choose the appropriate forum for your topics. Abandon the way you use google groups. :D
Matt W
Re: Cubeitmod V4.9
Post by Matt W »
Not a problem. I was debating where to put the post. I guess I got to used to the "free for all" of google groups. :D
Hugues
Re: Cubeitmod V4.9
Post by Hugues »
Check the printer tab/ firmware/ postprocessor name. It has to match with the cubeitmod.exe file name.
Regards
regards,
Hugues
www.cubexupgrade.com
Matt W
Re: Cubeitmod V4.9
Post by Matt W »
Yep, I made sure of that cause I have made that mistake in the past. Thanks though.
Matt W
Re: Cubeitmod V4.9
Post by Matt W »
Never mind I figured it out.
