Hi all,
I am new to this forum. I am posting about a problem I have with version 1.5. I need to slice a big model, the stl file is approx 500Mb, but kisslicer 32bit crashes. I thought it could be a problem of memory that could be worked around with the 64bit version. I downloaded the 64bit version but this one doesn't even start. It generates a generic error message as soon as one tries to run it and dies. It doesn't even open the main window.
How can I help you find out what is wrong?
My system is a Windows 7 Professional x64 service pack 1.
Best regards,
mcirri
Version 1.5 64 bit doesn't start
- EddyMI3D
Re: Version 1.5 64 bit doesn't start
Hello mcirri!
Any kind of error message?
What does it say?
I assume you downloaded this version.
Sometimes even zip files can be corrupted during downloading. Downloading again may help.
Regards,
Eddy
What does it say?
Regards,
Eddy
Hi Eddy,
I downloaded the 64 and 32 bits from the website. I downloaded several times. The error for the 64 is in the attached file. The fact is that the error gives really little hint on what is the problem.
Mcirri
Mcirri
- Kisslicer64_error.png (22.93 KiB) Viewed 2397 times
- EddyMI3D
Hello mcirri,
this error message seems to be generated by Kisslicer, so Jonathan (lonesock), the author, should be able to help.
Regards,
Eddy
Regards,
Eddy
