Hi is there a way to modify the print layer thickness after the print has started.
That is I want to start the print layer at 0.32mm then decrease that to 0.1 towards the top of the print.
Changing the layer thickness mid print
- EddyMI3D
Re: Changing the layer thickness mid print
You can accomplish that in this way:
Here you can set your first layer thickness. (e.g. 0.32 mm)
While in
you set your usual thickness.
Ed
Printer -> Hardware -> Bed Roughness
While in
Style -> Layer Thickness
Ed
Thanks I did know about that method.
I am more interested in say printing 20 layers one at 0.32mm then the remaining 10 with 0.1mm.
In short: slice twice and cut'n' paste. Longer explanation: Slice the part with 0.32 setting, save it and then slice part with 0.1mm setting (otherwise same settings) and save to different name and then just replace the gcode in the 0.32 file for the layers you wish to print 0.1mm from the 0.1 file. Make sure the ending and starting layers match. For example if your last 0.32 layer is at height 3.20, then cut and paste layers starting 3.30 in the 0.1 file.MysticDarkLord wrote:Thanks I did know about that method.
I had a part that required 0.1 mm layers for only the top part. So I made two styles with all the same settings except for the layer thickness and sliced the same part with each style setting and saved the gcode with different names. Then just editor magic. Pretty easy but laborous. I'd rather have something like Slic3r has but without the bugs.
EDIT: Here is example of quick'n'dirty PHP script to merge the files:
<?php
$end_fp1 = 9.75; // where to end merge (not included!)
$start_fp2 = 9.6; // where to start merge (included!)
$fp1 = fopen("250.clean.gcode", "r") or die("can't read file");
$fp2 = fopen("100.clean.gcode", "r") or die("can't read file");
// skip crap
function txt_seek($fp, $needle, $cut = false)
while (!feof($fp)) {
$line = fgets($fp);
if (FALSE !== strpos($line, $needle)) {
return $line;
echo (!$cut) ? $line : '';
echo txt_seek($fp1, '*** G-code Prefix ***', true);
echo txt_seek($fp1, '*** Main G-code ***', false);
txt_seek($fp1, "BEGIN_LAYER_OBJECT z={$end_fp1}", false);
echo "; END 0.250 layers, START 0.100 layers
fclose($fp1);
echo txt_seek($fp2, "BEGIN_LAYER_OBJECT z={$start_fp2}", true);
while (!feof($fp2))
$line = fgets($fp2);
echo $line;
fclose($fp2);
