Interface path
Interface path
I would like to have the Interface solid path using the same crossed path of solid path.
With solid path the each layer is crossed with the previous layer.
With Interface solid path each layer has the same direction as the previous layer, crossing the layers gives better surface quality !!!
Re: Interface path
The Support/Model Interface code is getting a big overhaul for the 2.0 version, with this feature included. I have version 1.5 in feature freeze so I can release it, but this is important enough I will look to see if there is a very easy fix using existing code.
Re: Interface path
lonesock wrote:The Support/Model Interface code is getting a big overhaul for the 2.0 version, with this feature included. I have version 1.5 in feature freeze so I can release it, but this is important enough I will look to see if there is a very easy fix using existing code.
Keep the focus on the 2.0, we can wait.
Thanks.
Giovanni
