KISSlicer V2.0 Alpha Fault Reports
Re: KISSlicer V2.0 Alpha Fault Reports
orcinus wrote:The model is perfectly flat.
If you want to upload the model, I can get it checked out.
Alexander Mundy
Large Nozzle Extrusion Problems
Post by Alexander Mundy »
Is this on the list to check? Has anyone else experienced this with large nozzles and layer heights?
I have built a new printer which is dedicated to larger objects with E3D Volcano and large nozzles. Using a 1mm nozzle with PETG @ 1.2mm extrusion width and 0.6 to 0.8 layer heights I am finding that solid infill is over extruded 5 to 10%. If I adjust for the solid infill to be correct the loops and perimeters are under extruded. I have made sure it is not a speed related problem by setting all loop, solid, etc speeds the same. Also have tried with and without Duet non linear extrusion applied. I did not notice this with my other printer with 0.4 or 0.6 nozzles with the same filament, however now that I check upon examination with magnifying glasses it does appear I am setting extrusion multiplier with the smaller nozzle machine to a balance where one is a hair over and the other a hair under extruded. With the larger nozzle it is a problem due to the large amounts of plastic it is extruding and I can't find a balance where after several solid layers it doesn't start building up but yet perimeters and loops are acceptable.
Using Premium 0.9.9 Win 32 May 10th 2019
Re: Large Nozzle Extrusion Problems
Alexander Mundy wrote:Is this on the list to check? Has anyone else experienced this with large nozzles and layer heights?
Any chance you could upload the G-code for me to have a look please?
Alexander Mundy
Here is one.
(funny that extension gcode isn't allowed)
Breather Box.zip
(408.46 KiB) Downloaded 460 times
Alexander Mundy wrote:Here is one.
Thanks, I will have a look.
Only Image and Zip files are allowed, which is the same as other forums I use.
Well, I spent a little while examining the solid paths on the first layer.
For whatever reason, the first layer is being printed at Z=0.558 and the extrusion width for one path is 1.0146mm. But you do have flow tweak set to 0.9, and therefore a flow tweak value of 1 should produce an extrusion of 1.127mm - still not the "expected" 1.2mm.
However, you have X and Y shrink values of 1% and I wonder if this is throwing the figures?
It doesn't look right. Can I please ask you to re-slice the model with flow tweak set to 1 and the shrink values set to 0 and upload the result?
Thanks.
Alexander Mundy
Loaded the last project for that file, but not sure some settings wern't changed so here is 4 files. 1 with 0.9 flow & 1 XY shrink, 1 with 1 flow & 1 XY shrink, 1 with 1 flow & 0 XY shrink, 1 with 0.9 flow & 0 XY shrink just to cover the bases.
Breather Box Flow 0p9 XY 1.7z
(304.86 KiB) Downloaded 456 times
Breather Box Flow 0p9 XY 0.7z
(304.81 KiB) Downloaded 461 times
Breather Box Flow 1 XY 1.7z
(305.93 KiB) Downloaded 456 times
Breather Box Flow 1 XY 0.7z
(306.11 KiB) Downloaded 449 times
frozen.rabbit
Post by frozen.rabbit »
still seeing crossing of internal perimeters with Stay Inside and Avoid Edges
orcinus
Post by orcinus »
Checked out for what?
Will you fix the issue if you "check it out"?
https://www.dropbox.com/s/2aeetfkmxjd8d ... y.stl?dl=0
setar
Post by setar »
alpha_2.0.6
Problem with generated language .pot file : not open by poedit.
manual fix (drop first and last line, convert to unix LF) :
tail -n+2 ./KISSlicer_language.pot |tail -r | tail -n +1 | tail -r | dos2unix >2.po
and additional manual edit with replace 0x0BA and 0x0C2 (not all)
P.S. alpha 1.6.3 - not have the bug
2.po.zip
(21.82 KiB) Downloaded 464 times
