Flow wizard
woody3dp
Re: Flow wizard
Post by woody3dp »
Thank you PJR, I've also zipped the STL file and the profile (*.ksp)
flow KS.rar
(115.53 KiB) Downloaded 294 times
Re: Flow wizard
With the Flow Wizard, I get different ranges depending on whether I'm near the seam or on the other side of the cube. I assume since the seam is not dialed in yet, it's best to first pick the best looking side of the cube for analysis and possibly re-do this test once the seam and other variables are dialed in?
Close To Seam
Close To Seam
Away From Seam
Away From Seam
Re: Flow wizard
Yes, go with the seam.
Re: Flow wizard
Ok, thanks.
