Page 14 of 19
Posted: 22 Aug 2017, 02:41
zimlorog wrote:Included is the gcode used, as well as my layer settings.
Any chance you could attach the model (STL) and the Project file (Menu/Project/Save Project As)
This will enable us to exactly replicate what is happening.
Thanks in advance
Posted: 22 Aug 2017, 14:03
by voyt
I find the checkbox "Support"> "Make solid" not working. (No difference in interface if checked, still 50%)
...or maybe I'm missing something?..
Posted: 22 Aug 2017, 14:30
by zimlorog
Sure thing.
Also, the print was successful when printing at just .3 layer height.
Posted: 23 Aug 2017, 15:15
by Beefeater
Printing a wall 2mm wide at the base and tapering to 0.25mm, with W=0.5mm nominal extrusion width. As the wall narrows, the path switches from 2 loops to 1 loop and a crown path, then 1 loop, then just the crown path. .STL and .KSP attached.
1. Kisslicer varies the width of the crwon path from 0.5W to 1.5W, but it is always displayed at 1.0W width in the preview. So one has to read G-code to know how Kisslicer decided to handle each situation.
2. Near the top, the preview shows the crown path in purple even if "color paths by extruder" is chosen. Near the bottom, crown paths are colored correctly by extruder.
BTW, "Unsupported paths - Slows speed but not extrusion rate (BFB)" is fixed in RC1.
Posted: 23 Aug 2017, 18:44
by lonesock
zimlorog wrote:Sure thing.
KISSlicer had put in some "NaN" values! Seems to be in a wipe path where a point was duplicated for some reason. I'll try to get you another build to test soon.
Posted: 23 Aug 2017, 18:48
by lonesock
voyt wrote:I find the checkbox "Support"> "Make solid" not working. (No difference in interface if checked, still 50%)
Make Solid is for the interface paths below the actual interface (top-most) paths, and it will be at least "Z Band" thick. If you want the actual top interface layer to be solid, make the Stride the same as the Width. Not sure if I explained that very well.
Posted: 23 Aug 2017, 18:51
by lonesock
Beefeater wrote:Printing a wall 2mm wide at the base and tapering to 0.25mm, with W=0.5mm nominal extrusion width. As the wall narrows, the path switches from 2 loops to 1 loop and a crown path, then 1 loop, then just the crown path. .STL and .KSP attached.
That's weird about the colors, but for the rest, crowning isn't that sophisticated yet...it only has a single width for a single path (supposedly at the average thickness for that crowning path, and limited from 50% to 150% of the extrusion width). If there are multiple crown paths they can each have a distinct width.
Posted: 24 Aug 2017, 00:46
by Beefeater
lonesock wrote:If there are multiple crown paths they can each have a distinct width.
But even when crown paths have different widths, preview still shows them at 1.0W. So I need to get into raw G-code each time to find out what Kisslicer had done. Anyway, I know you have bigger fish to fry right now. No worries.
Boris
Posted: 24 Aug 2017, 12:32
by xmas75
Missing support in the middle.
missing support
missing support
Posted: 24 Aug 2017, 12:33
by xmas75
Upside down for test more missing, and settings window.
missing
missing
