Page 2 of 2
Re: CUBEITMOD V6.05 Fatal Error.!
Posted: 30 Mar 2016, 15:43
by Giovanni V.
jaydie wrote:Here are the INI file, Im not sure which BAK file is needed. is it the bfb.bak? If that is nothing was created or may be I don't know where to get it. I just include the po.bak.
Thanks so much for looking at it.
Material in extruder 1 has only 15 Max speed, set to 50.
Posted: 05 Apr 2016, 12:32
by jaydie
Here is a BAK file, but this was generated with Cubeit491, I have the fatal error when I change to Cubeit605
Posted: 05 Apr 2016, 14:18
by Giovanni V.
jaydie wrote:Here is a BAK file, but this was generated with Cubeit491, I have the fatal error when I change to Cubeit605
You didn't change the Max Speed, set Max Speed = 50 on ALL THE MATERIALS you selected for ALL the extruders even if you don't use the extruder during the print.
Posted: 05 Apr 2016, 14:48
by jaydie
Finally got v6.05 working. I downloaded the Kisslicer 2.22 and start as a new.
