KISSlicer Win64 v2_alpha 1.6.3
What's new in this version?
- ksh_germany
Re: KISSlicer Win64 v2_alpha 1.6.3
Did you read the change log file? You find IT in Dropbox folder where you can download pre_alpha versions
Greetings from Germany
Beantworte fragen zu Kisslicer auf deutsch
Thank you found itksh_germany wrote:Did yiu read the change log file? You find IT in Dropbox folder where you can download pre_alpha versions
* 2019-10-21
v2a1.6.3
Only adjust first layer Z-Gap when raft is enabled.
Added the Premium Key's form to the invalid key message.
Improved patch grid sampling.
I think there's more, you should start reading from the last release, not just the last entry.Cthutq wrote:Thank you found itksh_germany wrote:Did yiu read the change log file? You find IT in Dropbox folder where you can download pre_alpha versions
* 2019-10-21
v2a1.6.3
