It was print with speed 25 for perimeter and loops.
It is very slowly.
I will try print with speed 5, but I think that will nothing change.
Flow rate for perimeter and loops is low
Re: Flow rate for perimeter and loops is low
If you set the Min Segment Length [mm] field in the Printer/Hardware tab of the Settings window to some value, then KISS will not produce segments shorter than those.
Tool tip suggests a value of (x/y resolution * 2) as a starting value, but I think segments less than 0.1mm are not particularly relevant, but even that may be too small. What firmware are you running (sorry if you mentioned it before...)?
Sorry, I really don't have much of a clue here, so just guessing really
At first time my printer "TEVO Tarantula" worked wrong:
- driver X move inverted and sensor X not worked.
... and something else, I can't remember now.
I saved original firmware to binary file.
Then I downloaded source files of firmware "Repetier 0.92.8", change the file Configuration.h a little and uploade to printer.
Zip-file attached.
Then, my printer became to work correctly.
I can restory original firmware but I not sure, is this a good idea.
What the name of options for "min segment lenghth" in Configuration.h?
What I will change Configuration.h or will set option "min segment lenghth" in KISSlicer?
What do u recommend for my situation?
I found this options in Configuration.h:
PS: I am sorry for my bad english.
And thank u for reply!
Zip-file attached.
#define DELTA_SEGMENTS_PER_SECOND_PRINT 180 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other moves
#define DELTASEGMENTS_PER_PRINTLINE 24
- Repetier_0.92.8.zip
- (432.56 KiB) Downloaded 241 times
Yeah, sorry, I think this is beyond my abilities.
I did find a section:
Which makes me think that segments will be ignored if the firmware can't handle the speed at which they are being delivered.
Try slicing again with KISS set to a 0.1mm min segment length.
// Now ignore enough segments to gain enough time for path planning
I maked 3 gcode-files in KISSlicer and visualise Perimeters.
Length of segmets in radial path: 0.62 - 0.75 mm.
Look to difference at picture below please (short perpendicular lines is markers end/begin of segments).
- min_seg_len.png (21.99 KiB) Viewed 2560 times
