I am trying to understand why this path color key appears and if it is a cause of concern.
The absence of an update reference manual is quite disorienting, so the developers redirect to this talk but there not actually clear answers to this issue.
What I am asking is:
-It is not clear why this is happening (it looks random to me sometimes) and what to do to get rid of this.
-If it is related to the material not actually being supported, how to change parameters to actually see it disappear?
Unsupported Section Tinting problem
Re: Unsupported Section Tinting problem
This slicer is not worth the trouble
It did produce rather good quality prints, but while printing outer perimeters at 15mm/s. Cura will drop printing speed for outer perimeters by 50%, Simplify3D by 30%, and KISSlicer by 70%
At least for me, slicing is really slow, around 15-20 seconds for some small models. Cura will take 3-4 seconds and CraftWare 1-2 seconds
No relevant documentation and no support.
The software is not open source and it's maintained only by a single developer. It has a small community as you can see from replies on forum posts.
Invest your time in Cura, Slic3r Prusa Edition and CraftWare.
Not debating if you should invest your time on this slicer or some other, but the speed settings are set ( Perimeter, Loops, Solid Infill, Sparse Infill, First layer speed, and increase speed per layer ) on the Printer -> Speed tab. Then on the Style tab, you can set the speed between your min and max for each. It really does have a lot of control.MatejEU wrote:.....
Indeed has a small community, therefore I'd expect that who replies, also actually tries to answer to the topic post. Otherwise, i don't see the point of this forum.
