qwalker wrote:Are there any differences between your post processor and the PRO version? I just started using KISSlicer and I want to continue after I upgrade
Hi Quentin
The KISS PRO license allows you to slice with multiple extruders (and use many more features within KISS). The Post Processor is a free program which (simplistically) will take the output from KISS and add a purge tower.
The post processor will do nothing unless you have the KISS PRO license and have sliced the model with multiple extruders.
FIX: Amended tower perimeters to bond better and increase the used preload value.
FIX: Reduce unload/load distance by 5mm to better match the latest PR firmware filament loading.
BeNe wrote:Is there a way to add support for print one after one (sequential) with your PostProcessor ?
No, sorry, doesn't support sequential model printing. Never been a fan of that method... Tried it once and nearly broke the printer (bent the heat break).
