Corner path are somethime very strange. it also seems to depend on the extrusion thickness. With 0.3 extrusion width is pretty bad.
This seems to happen with several kisslicer free version and the 1.5 release
is it my fault?
Config files and STL attached
Strange corner path
- Ultim - Yoann
Strange corner path
- Cube.zip
- (713 Bytes) Downloaded 357 times
- KISSlicer_Win64_1.5_Release_config_files.zip
- (2.3 KiB) Downloaded 354 times
Re: Strange corner path
I'm seeing clipped corners in 1.5 release, and a bit of non linear path at corners in 1.2.0.1 release. Oversample resolution doesn't have much effect. This can't be good for level of detail. 0.2mm extrusion width.
