Seam hiding
Ultim - Yoann
Re: Seam hiding
Post by Ultim - Yoann »
Material : PLA E-sun
Hot End : E3D V6 0.4mm with 0.45mm in Kisslicer extrusion width parameter
Layer : 0.2mm
Print Temp : 220°
Medium speed print (~30mm/s)
Seam Hiding.jpg (14.55 KiB) Viewed 4245 times
Re: Seam hiding
Looks great. Do you use bowden or direct drive extruder? If bowden, how long are the PTFE tubes and did you have strings?
Epop
Re: Seam hiding
Post by Epop »
holy jesus... retract & prime might be an issue as will Z lift.
a picture of what I'm getting ATM (just slightly under extruded at path start)... the seam is just above the flash highlight
PLA natural .2mm layer height
S-plug-PLA 2mm layer.jpg (76.69 KiB) Viewed 4161 times
If you want settings/more pictures etc... let me know.
3D Systems - CubePro Trio (triple head printer)
--Modified to RepRap standards using Duet and the x4 expansion
-e3d Kraken, heated bed added.
Kisslicer Pro licenced
de_kaminski
Re: Seam hiding
Post by de_kaminski »
Ultim - Yoann: Das ist Lecker!!
Very nice result!
http://www.bigrep.com dekaminski@bigrep.com
Zmorph 2.0s BigRep One.2 KISSlicer Pro, Simplify 3D
jaydie
Re: Seam hiding
Post by jaydie »
Ultim - Yoann wrote:Hi,
Layer : 0.2mm
Print Temp : 220°
Trying these setting now...
voelkerp
Re: Seam hiding
Post by voelkerp »
I'm also having a bad time with this issue. It wasn't a problem before and I'm not sure when it changed but I can't get rid of it now. I'm using kisslicer 1.5.2.22 64 bit. I've tried reducing the seam hiding gap and depth to 0.1 and also have done many iterations with suck and push but when I reduce the push by enough to see a difference in that starting bubble, the remaining extrusion for that layer suffers significantly. :-(
