Thought I would post a quick update on the progress of the fully re-brained CubeX.
What started out as a regular CubeX has now been converted to a fully functioning open source machine.
Currently Setup:
12v 12''x12'' heated PCB print bed with glass top
Arduino mega 2560
RAMPS 1.4 Shield
DRV8825 drivers
LCD with SD
Stock belts
Stock threaded rod
dual 12v 360W power supplies
Dual E3d v6 hot ends
Modified CubeX
Re: Modified CubeX
Nicely done!
Very clean looking conversion.
Any plans to re-locate the LCD to the factory position?
Re: Modified CubeX
very much so. Just having trouble finding a set of cables that are long enough. So far, I've the longest I've been able to purchase are 300mm
Pgregory wrote:Nicely done!
Re: Modified CubeX
Nice man
I have two of them and i'm planning on doing that mod.
Can you please share more details on that?
See you
See you
- aerre3d
Re: Modified CubeX
Good work !!!
I'm "push-up" Piraz
I'm "push-up" Piraz
Maker or not Maler, this is the question.......
Re: Modified CubeX
Nicely done !
So originaly it had one hot end ? and now you upgraded to 2 .
so now u can print suport material with the second one ?
do you have any more pictures and/or explanation for that ?
Thank you
Thank you
Re: Modified CubeX
could you tell me how to install the e3d hotends on the cubex?
Re: Modified CubeX
How to wire the e3d v6 on the cubex duo?
