Can I type in the angle for seam hiding as well as keep the
Can I type in the angle for seam hiding as well as keep the spinning selector? If the spinning selector was a bit bigger it would also be easier to use.
- PenskeGuy
Re: Can I type in the angle for seam hiding as well as keep
Agreed. It's difficult to fine tune the angle. It doesn't need to be any larger if there is a keyboard method of adjusting it; similar to the Fast/Precise slider that also operates with arrow keys. I'd also appreciate a Reset that sends it back to the default 45° vector.
Well, until we don't have that, you can always go to the _styles.ini file and manually edit the seam angle.
Yes, my problem as well! I want actually to see the angle on the model if I change it.
Or there could be an optin to put the angle to the nearest corner!
- PenskeGuy
You can see it easily when it slices by turning Wipe on.
I totally agree with frankjoke, for some parts and specially for some materials with particulars optical properties it would be better to have the possibility to have the seam into the nearest corner.
